Takex 30m Ext / 60m Int Twin Active infra red Beam
Description
Our Twin photoelectric beams are designed to meet the highest standards of quality and reliability for photoelectric beam intrusion detection. Unique twin beams are synchronised to work together to reinforce range and stability in severe weather conditions.
For distances up to 30m (100ft) outdoor / 60m (200ft) indoor, the PB-30TK provides the ideal solution when cost is a major concern.
note: TK series Twin Beams are 'Single Channel' units for simple beam systems. For more complex systems eg. multiple stacked beams or in-line systems use PB-TE series 4-Channel units to avoid 'Crosstalk'.
  • Synchronised Twin Beams for reliable detection
  • Double Modulated Beam type ensures unsurpassed immunity to direct and reflected sunlight and vehicle headlights
  • Multi-Meter Test Points to accurately monitor alignment voltage
  • Frost Resistant Cover minimises nuisance alarms in harsh weather
  • Automatic Gain Control for maximum stability
del
PB-30TK
Product type
Photoelectric Beam Sensor
Detection system
Simultaneous breaking of 2 beams
Infrared beam
LED pulsed beam, Double modulation
Protection distance
Outdoor 30m (100ft) or less
Indoor 60m (200ft) or less
Beam arrival distance (max.)
Outdoor 300m (1000ft) or less
Indoor 300m (1000ft) or less
Response time
50msec. to 700msec. (Variable at pot)
Supply voltage
10V to 30VDC (Non-polarity)
Current consumption
53mA or less
Alarm output
Dry contact relay output form C
Contact action : Interruption time + delay time
Contact capacity : 30V AC/DC, 0.5A or less
Tamper output
Dry contact relay N/C (Receiver only)
Action : Activated when cover is detached
Alarm LED
Red LED (Receiver)
ON : when an alarm is initiated.
Attenuation LED
Red LED (Receiver)
ON : when beam is attenuated.
Functions
AGC circuit
Frost proof cover
Ambient temperature range
-25°C to +60°C (-13°F to +140°F)
Mounting positions
Indoor / Outdoor
Wiring
Terminals
Weight
Transmitter : 380g (13.3oz)
Receiver : 400g (14oz)
Appearance
PC resin (wine red)
  • Model: PB-30TK
  • Shipping Weight: 1.2 kgs
  • Manufactured by: Takex
£100.98 Ex VAT
