24v 4 tone Sounder 103Db White
VPR SA4E Spatial Sounder 24Vdc
The SA4E version of the VPR EN54-3 approved sounder has been designed to deliver maximum sound output and achieves a healthy 103dB(A), making it ideal for a wide range of applications such as industrial, security and fire,making the device a truly multi-purpose high output sounder.
Approved to EN54-3 the VPR offers 4 distinctive and selectable tones. Other variants in the range include an approved Dutch sounder and 110/230v AC mains variants. The devices also offer a changeover facility from the Alert toEvacuation tone, when installed using three core cable.
  • 4 standard tones and specific Dutch tone
  • Synchronised
  • Continuously variable volume control
  • Designed to work with both conventional and two-wire (SAV-WIRE®) systems
  • IP65 specification for all SA4 variants
  • Standard base locking system
Voltage range Vdc 20 - 35
Number of tones 4
Operating frequency - Hz 800 - 1000
Temperature range °C-20 to +70
Monitoring Reverse polarity
Protection rating IP33C
Boxed weight(kg)0.20
Performance
Version SA4
Sound output, typical dB(A)103
Max. current consumption @ 24Vdc mA32
  • Model: 505-007
  • Manufactured by: Cranford Controls
£21.00 Ex VAT
