ACT Filters
Displaying 1 to 11 (of 11 Products)
ACT1166
ACT Filters
ACT Filters
ACT 1166 Earth Line Choke Filter
Many metal control panels connect 0 Volt of the 12VDC supply to the metal box which in turn is connected to mains Earth. This...
£10.25 Ex VAT
Add to CartACT1313
ACT Filters
ACT Filters
ACT 1313 AC Spike Filter For Intruder Alarms
To eliminate potential false alarms caused by induced AC, fit an ACT 1313 to the control panel and each remote PSU as standard. Understanding Induced...
£10.49 Ex VAT
Add to CartACT230MSF
ACT Filters
ACT Filters
Prevents false alarms and system malfunctions caused by EMI/RFI signals and nearby lightning via the 230VAC mains supply. The ACT 230MSF protects...
£20.70 Ex VAT
Add to CartACT2323
ACT Filters
ACT Filters
Providing up to 4,500 Amp spike suppression, the ACT 2323 protects all security and fire alarm panels, CCTV cameras and access control equipment...
£16.64 Ex VAT
Add to CartACT1414
ACT Filters
ACT Filters
Stop induced AC and nearby lightning from affecting the fire alarm panel with the ACT 1414. Fitted as standard, this 24V spike suppressor will...
£8.55 Ex VAT
Add to CartACT-1313-PLUS
ACT Filters
ACT Filters
ACT Advanced 12V Spike Suppressor
The ACT-1313-PLUS not only eliminates false alarms caused by induced AC and RFI interference but can also identify cable faults supplying DC...
£19.08 Ex VAT
Add to CartACT612
ACT Filters
ACT Filters
Take seconds to receive accurate Ampere hour (Ah) capacity results of the most common lead acid battery types. The ACT 612 Intelligent Battery Tester...
£299.95 Ex VAT
Add to CartCPS3+
ACT Filters
ACT Filters
ACT Intruder Control Panel Filter Kit
Kits comprise of: This kit provides the best protection against RFI, as well as EMI and nearby lightning, via the AC, DC supply and earth, for...
£31.48 Ex VAT
Add to CartACT/6000
ACT Filters
ACT Filters
ACT/6000 Alarm Engineers Autoranging Multimeter
ACT proudly introduce the all new ACT/6000 Alarm Engineers Digital Multimeter. This fantastic meter, exclusive to ACT, incorporates many special...
£85.32 Ex VAT
Add to CartGOLD-PLUS
ACT Filters
ACT Filters
ACT Gold-Plus 6/12v Intelligent Battery Tester
OBSOLETE - Alternative Click Here The ACT GOLD-PLUS is a dual voltage intelligent battery tester, designed for 6V and 12V lead acid...
£183.59 Ex VAT
... more infoBATMASTER
ACT Filters
ACT Filters
ACT InHouse Battery Tester Calibration Test Box
OBSOLETE - No longer available BATMASTER allows you to perform in-house testing and re-calibration of RED/GOLD-IBT and GOLD-PLUS intelligent...
£313.00 Ex VAT
... more infoDisplaying 1 to 11 (of 11 Products)
