ADE Honeywell Optima Compact Gen4 8EP396A
Optima Gen 4 Burglar alarm panel, latest in the Honeywell range of a very reliable product, already installed in millions of homes, easy to install. One of our most popular and as said before easy to install panels
8 Zones
3 part set programs
Simple set readers for ease of operation
Personal attack facility
5 Digi-Outputs
New LCD Keypad
The LCD remote keypad operates with the Accenta and Optima Gen4 intruder systems. Up to four LED or LCD keypads can be connected to the system. The large 2x16 characters with backlight display provide a full status indication and the keypad plays entry and exit tones.
Fire Zone
250-event log
Duress Code
Chime
Can be used to select a low security chime alarm for various areas of your house, even when the main alarm is turned off. When a door is opened or a detector triggered in an area set to chime, the control panel will deliver a low-volume
  • Model: 8EP396A-UK
  • Shipping Weight: 1.8 kgs
  • Manufactured by: Honeywell
£39.86 Ex VAT
