Apollo
Displaying 1 to 12 (of 56 Products)
MX5101
Apollo
(image for) Advanced Single Loop Panel in Standard Enclosure
Features 20 programmable zonal / 25 System LEDs. Apollo, Argus Vega, Hochiki & Nittan Evolution protocol support. Advanced graphical LCD user...
£699.98 Ex VAT
Add to Cart
45681-510
Apollo
(image for) Apollo Alarm Sense Sounder Base
The base can only be used with AlarmSense systems. It is fitted with electronic circuitry to monitor the presence of detectors and signals any...
£17.50 Ex VAT
Add to Cart
45681-244APO
Apollo
(image for) Apollo Alarmsense Base
AlarmSense detectors can only be mounted into the AlarmSense Base. The base is used for installing detectors that do not require an integral sounder...
£3.24 Ex VAT
Add to Cart
55400-894APO
Apollo
(image for) Apollo Alarmsense Manual Call Point
The Manual Call Point has been designed to operate on an AlarmSense two-wire loop. An alarm is initiated by pressing the resettable element, which...
£13.94 Ex VAT
Add to Cart
55000-018APO
Apollo
(image for) Apollo Alarmsense Open-Area Sounder Red Body
The AlarmSense Open-Area Sounder is designed for use in open-areas. Polarity insensitiveIP65 ratedApollo tone - synchronised with AlarmSense sounders...
£32.50 Ex VAT
Add to Cart
45681-509
Apollo
(image for) Apollo Alarmsense Sounder Vid Base (Red Flash)
The base is designed to be used with AlarmSense systems only. It is supplied with a low or high volume setting and red or white caps are available...
£25.92 Ex VAT
Add to Cart
45681-210APO
Apollo
(image for) Apollo Discovery Base with XPERT Card
The XPERT 7 Base is a low insertion force base with stainless steel contacts allowing easy and quick installation. XPERT addressing XPERT cards...
£5.68 Ex VAT
Add to Cart
58000-300APO
Apollo
(image for) Apollo Discovery Carbon Monoxide Detector
The Discovery Carbon Monoxide Detector contains a long-life electro-chemical carbon monoxide sensor which is tolerant of low levels of common vapours...
£76.38 Ex VAT
Add to Cart
58000-400APO
Apollo
(image for) Apollo Discovery Heat Detector
The Discovery Heat Detector features a low air flow resistance case and a single thermistor to sense the air temperature around the detector....
£57.14 Ex VAT
Add to Cart
58000-500
Apollo
(image for) Apollo Discovery Ionisation Smoke Detector
Air in the dual sensing chambers is irradiated to produce ions that travel to the positive and negative electrodes, creating a current flow. As smoke...
£57.14 Ex VAT
Add to Cart
58100-910APO
Apollo
(image for) Apollo Discovery Manual Call Point
The Discovery Manual Call Point is commonly used to manually control extinguishant release. EN 54-11 Certified Reports an alarm in under 0.2 seconds...
£57.14 Ex VAT
Add to Cart
58100-908APO
Apollo
(image for) Apollo Discovery Manual Call Point - Isolating
The Discovery Manual Call Point is used to manually initiate an alarm signal on the fire detection system. EN 54-11 & EN 54-17 Certified Reports...
£59.38 Ex VAT
Add to Cart
