Apollo Series 65 12V Relay Base (For use with Series 65 Heads)
The base is designed for use in both fire and security systems. For fire systems a jumper on the PCB is fitted to a ‘latching’ position. For security systems the jumper is moved to another position so that the base is ‘non-latching’.
  • Detector locking mechanism
  • One-way fit
  • Easy to wire
  • Contains an earth connector
  • Can be used in fire and security systems
  • 10 Year Warranty
See below Drawing
System Diagram
  • Model: 45681-508APO
  • Shipping Weight: 0.1 kgs
  • Manufactured by: Apollo
£7.67 Ex VAT
