Aritech Advisor Advanced Residential Keypad
Description
ATS1135 Advisor Advanced Residential keypad with built-in reader
The ATS1135 offers a stylish design providing for clear and readable text on a 2 x 16 characters LCD for displaying system configuration and information. The contrast and intensity of the display is adjustable via the keypad, as well as the volume level of the build in buzzer. Four arrow keys together with nine dedicated function keys provide for easy navigation through system configuration menu's or day-to-day operations. The 3 configurable function keys underneed the LCD provide an easy shortcut to execute a function of the system. Four status LED's will continuously update the user on mains power status, faults, and alarms. The ATS1135 can display the status of 8 areas using the indications on the LCD display, besides vizualizing the status of 1 or more areas via the clear Red/Green status indication. The ATS1135 can be mounted at a distance of 1.5 km from an Advisor Advanced control panel. The backlit screen and keys highlight the keypad for use during day or night. Even in places where lighting is poor the display has an excellent performance. The backlit functionality is programmable. In non-alarm situation the keypad may show a free programmable text. ATS1135 features a build-in smart card proximity reader, one open collector output for door control and one dedicated request to exit input.
Product Features
  • Stylish design
  • Simplified end user operation
  • Large 2 x 16 characters LCD
  • User adjustable LCD contrast
  • User adjustable buzzer
  • Built-in smart card proximity reader
  • Compatible with all Advisor Advanced control panels
  • Clear system status indication
  • 3 programmable function keys
Technical specs
Supply voltage
  8.5-14 VDC Max
Current consumption
 Normal (all areas armed)
  35 mA @ 13.8 VDC
 Maximum
  155 mA @ 13.8 VDC
Outputs
 Open collector
  15 VDC Max @ 50 mA Max
Dimensions
 with cover (W x H x D)
  200 x 90 x 24 mm
Operating temperature
  -10 to +55°C
Humidity
  95% non condensing
Weight
  350g
IP rating
  IP30
  • Model: ATS1135
  • Manufactured by: GE Security
£66.83 Ex VAT
