Aritech Single Zone Shock Sensor Analyzer
Shock Sensor Analyser
The single multi count analyser has an amplitude setting which allows the installer the flexibility of adjusting the level of a single shock to give an alarm activation. The analyser also has a programmable 1-second count facility which enables the alarm to be activated after a series of small shocks are received at 1-second intervals. The counter is programmable between 1-9 counts within a fixed time period of 30 seconds. If the programmed number of small shocks is received, or if one shock larger than the setting of the potentiometer is received the alarm will activate.
Application
Residential are typical applications for these shock sensor analysers. The gross attack setting will trigger an alarm when a shock big enough is applied to the window/door. The pulse count setting will detect an intruder gently shocking a window/door after a selected number of shocks at 1-second intervals.
EOL Resistor
The sensor loop contains a 1K end-of-line resistor wired in series with the sensors. Should the sensor loop be cut or the 1K end-of-line resistor be shortcircuited, the alarm will be activated.
Technical specifications
Sensitivity setting Yes
Programmable pulse count, 1-9
LED indication Yes
On-board voltage regulation Yes
EOL resistor Yes
Reset Auto / Manual
Product type Shock sensor analyser
Alarm contact 12 VDC, 1 A
Tamper switch Yes
Wired-wireless Wired
Operating voltage 10-15 VDC
Current consumption
10 mA (quiescent)
50 mA (alarm)
Operating temperature -40 to +50°C
  • Model: GS615-W
  • Shipping Weight: 0.32 kgs
  • Manufactured by: GE Security
£29.33 Ex VAT
