Bosch
Displaying 1 to 12 (of 70 Products)
LHM0606/10
Bosch
(image for) Bosch 100V Line Ceiling Loudspeaker, 6W RMS - LHM0606/10
The LHM 0606/xx is a general purpose, 6 W, costeffective ceiling loudspeaker. The /00 version is screw mounted and the /10 version is clamp mounted...
£20.70 Ex VAT
Add to Cart
LBC3481/12
Bosch
(image for) Bosch 10w Horn Loudspeaker
10watt Circular Horn Load Speaker Bosch high-efficiency horn loudspeakers provide excellent speech reproduction and sound distribution for a wide...
£65.70 Ex VAT
Add to Cart
LBC3492/12
Bosch
(image for) Bosch 20w Horn Loudspeaker
20watt Circular Horn Speaker Bosch high-efficiency horn loudspeakers provide excellent speech reproduction and sound distribution for a wide scope of...
£111.00 Ex VAT
Add to Cart
LBC3483/00
Bosch
(image for) Bosch 35w Horn Loudspeaker
Bosch high-efficiency horn loudspeakers provide excellent speech reproduction and sound distribution for a wide scope of outdoor applications. They...
£178.00 Ex VAT
Add to Cart
LBC3950/01
Bosch
(image for) Bosch 6w Compact Ceiling Loudspeaker
The LBC 3950/01 is a compact, 6 W loudspeaker with a circular plastic grille. It has excellent audio performance and is easy to install with its...
£18.33 Ex VAT
Add to Cart
PLE-IMA030-EU
Bosch
(image for) Bosch Audio 30W Mixing Amplifier
These Plena mixer amplifiers are high performance, professional public address units with modern state of the art features. They are easy to use,...
£168.00 Ex VAT
Add to Cart
VG4-A-PA0
Bosch
(image for) Bosch AutoDome Pendant Arm Mount
Dome wall bracket for Bosch AutoDome 600 Series Analog PTZ Camera Dome Pendant-Clear Camera not included
£267.80 Ex VAT
Add to Cart
ISC-BPR2-W12
Bosch
(image for) Bosch Blue Line Gen2 Passive-infrared Detector
£10.64 Ex VAT
Add to Cart
ISC-BPR2-WP12
Bosch
(image for) Bosch Blue Line Gen2 Pet Friendly Passive-infrared Detector
The Replacement of the popular BLP1 PIR, the BlueLine Gen2 PIR Motion Detectors (ISC-BPR2) use two Fresnel lenses designed to produce sharply-focused...
£21.12 Ex VAT
Add to Cart
ISC-BPQ2-W12
Bosch
(image for) Bosch Blue Line Gen2 Quad PIR Motion Detector
Component issue unable to advise new stock date PIR Motion detector, 40ft (12m) CTN: ISC-BPQ2-W12 | Product No.: F.01U.364.871 Dynamic Temperature...
£21.00 Ex VAT
... more info
LTC 9210/01
Bosch
(image for) Bosch Column Mount 20mm Indoor/Outdoor
The LTC 9210/01, LTC 9215/00, LTC 9215/00S, LTC 9219/01 and the LTC 9223/01 feed-through mounts are indoor/outdoor mounting units designed for fixed...
£22.38 Ex VAT
Add to Cart
LTC9223/01
Bosch
(image for) Bosch Column Mount 610mm Indoor/Outdoor
£31.50 Ex VAT
Add to Cart
