Castle Care Tech Euro LCD RKP built in Prox Reader
Ideal for use on the EURO and Enforcer control panels in a residental or commercial setting.
You can quickly easily and securly arm and disarm your security system with either a proximity tag or by typing in your user code.
Compatability
EURO 064 - EURO 46, EURO 162, Enforcer & HomeControl+ Panel
EURO 068 - EURO 46, EURO 162, Enforcer & HomeControl+ Panel
EURO 069 - EURO 46, Enforcer & HomeControl+ Panel
Security Code
This function is needed to address each keypad connected to the PCX control panel.
Keypads and readers
This function is used to assign each keypad to the RS485 bus and any areas that are programmed.
LEDs
Ready: Indicates that no inputs are active and the control panel is ready to be armed.
Alarm: Indicates an alarm activation has occurred.
Tamper: Indicates a tamper activation has occurred.
Fault: Indicates a fault warning on the control panel. If flashing, the engineers menu has been accessed.
Disarmed: Indicates the control panel has been disarmed.
Technical Specifications
Setting devices technical characteristics
Plastic LCD keypad with icon display
Yes
Intergrated prox reader
Yes
IP 64 rated external prox reader
No
Activate output automation
Yes
Backlit Keys
Yes
Tamper protection
Yes
Inputs & outputs
Onboard wired inputs
2
Outputs on board
1
Environmental and operating features
Certified operating temperature
-10°C to +40°C
Physical dimensions (H x W x D)
99 x 144 x 34mm
Weight
256g
Certifications and warranty
Electrical conformity
CE
EN Certificate
EN50131-3:2009
EN50131-1:2006+A1:2009
PD6662:2010
Certification type
Self certified
Environmental class
II
Warranty
2 years
Security Grade
Grade 3
Proximity Tag reader to set/unset the system
Options:
Proximity Tags
  • Model: EUR-068
  • Manufactured by: Castle Care-Tech
£68.94 Ex VAT
