Ditec Automation
Displaying 1 to 8 (of 8 Products)
Dit-Sprint
Ditec Automation
Ditec Automation
Automatic Door Operator - Sprint 100Kg Door Medium Duty
Dimensions, 450x80x90mmMaximum Load, 100kgOperating system, Motor Open, Motor CloseOpening Speed 3 to 5 secondsClosing speed, 70% of full speed for...
£539.21 Ex VAT
Add to Cart4SAFE350+700
Ditec Automation
Ditec Automation
Ditec 4SAFE On door active infrared sensor
On door active infrared sensor with background suppression distance measurement via triangulation 350mm 1.1m to 3.5m mounting height IP52 350(L)...
£390.00 Ex VAT
Add to CartWEL-M
Ditec Automation
Ditec Automation
Ditec Automatic pedestrian swing doors Heavy Duty 250kg (WEL-M)
Automatic pedestrian swing doors - WEL This automation comes in versions E, M and S.
£799.00 Ex VAT
Add to CartCOM-E
Ditec Automation
Ditec Automation
They are the new electronic mechanical and analogue program selectors designed to select and set desired operation modes for one or more automatic...
£176.00 Ex VAT
Add to CartDFA-127
Ditec Automation
Ditec Automation
Ditec Heavy Use electro-mechanical swing door operator
The universal, electro-mechanical DFA 127 swing door operator system The universally installable, electro-mechanical operator is the highly efficient...
£835.00 Ex VAT
Add to CartFINGUARD[B]
Ditec Automation
Ditec Automation
Ditec Plastic Fingerguard - Brown
Ditec Plastic Fingerguard - Brown For use with Record DFA127
£55.00 Ex VAT
Add to CartFINGUARD[W]
Ditec Automation
Ditec Automation
Ditec Plastic Fingerguard - White
Ditec Plastic Fingerguard - White For use with Record DFA127
£55.00 Ex VAT
Add to CartHOTSSS-5S1
Ditec Automation
Ditec Automation
Ditec SSS-5 Monitored Swing Door Safety Sensor
Full Swing Door Safety with only 1 PCB unit The SSS-5, with 6 spots of detection per PCB unit ensures pedestrian safety levels exceeding EN16005...
£230.00 Ex VAT
Add to CartDisplaying 1 to 8 (of 8 Products)
