Eaton Security
Displaying 1 to 12 (of 100 Products)
DET-RDC-B
Eaton Security
(image for) Eaton Slimline Door Contact Brown
Eaton DET-RDC-G Scantronic Slimline Door Contact - Brown Wireless slimline detector range is used for detecting threats at perimeters and alerting...
£36.99 Ex VAT
Add to Cart
794REUR-00
Eaton Security
(image for) Eaton 1/2 Wave Antenna For Wireless System
Indoor/Outdoor 1/2 Wave Aerial with 3m Coax Cable and Fixing Bracket [794rEUR-00] Antennae for 700R: Connection via BNC socket Technical...
£193.54 Ex VAT
Add to Cart
797REUR-00
Eaton Security
(image for) Eaton 1/2 Wave Collinear Aerial
Indoor/Outdoor 1/2 Wave Length Antenna with 3m Coax Cable and Fixing Bracket [797reur-00] Antennae for 700R:  Connection via BNC socket 1/2 wave...
£95.15 Ex VAT
Add to Cart
792REUR-00
Eaton Security
(image for) Eaton 1/4 Wave Antenna Aerial
Eaton antenna for intruder system, 1/4 wave antenna for use with 703reur and 790reur Connection via BNC socket Eaton Was Scantronic
£29.20 Ex VAT
Add to Cart
EXP-W10
Eaton Security
(image for) Eaton 10 Zone 4 Output Wired Expander For I-Onex Range
The EXP-W10 is a 10 zone wired expander designed for the i-onEX range of control units. This expander provides connections for: Either 10 Fully...
£74.96 Ex VAT
Add to Cart
EXP-PSU-SM
Eaton Security
(image for) Eaton 10 Zone Intelligent Powered Expander
A range of wired expanders designed and approved to be used as part of a security grade 2 or 3 system. Bus connected intelligent expanders are...
£99.04 Ex VAT
Add to Cart
EXP-R10
Eaton Security
(image for) Eaton 10 Zone Radio Wireless Expander For I-On Ex Range
Description The radio expanders for the i-onEX range of control units provide channels for either 10 radio detectors (EXP-R10) or 30 radio...
£69.98 Ex VAT
Add to Cart
DET-WDTPT-G2
Eaton Security
(image for) Eaton 12M Dual Tech Detector Pet Tolerant
Eaton wired and radio dual tech detection DET-RDT-G2 DET-RDTPT-G2 DET-WDT-G2 DET-WDTPT-G2 An internal detector with dual technology detection...
£33.85 Ex VAT
Add to Cart
9040UK-00
Eaton Security
(image for) Eaton 16 Ohm Extension Speaker
16ohm extension speaker in tampered housing. The 9040 is designed to emit all system tones including entry and exit tones, alarm and fault...
£13.34 Ex VAT
Add to Cart
705REUR-00
Eaton Security
(image for) Eaton 2 Channel Wireless Hold Up Device (Hud) Panic Alarm Button
Hopefully, your staff will never need to find out why our personal attack transmitters are so highly regarded. But should they ever be attacked,...
£105.96 Ex VAT
Add to Cart
KEY-RKPZ-KIT
Eaton Security
(image for) Eaton 2 Way Radio Keypad and Base Station Kit
Fully compatible with Scantronic i-on range and new Menvier panels, Eaton’s two-way KEY-RKPZ keypad enables tidier wire-free domestic installation....
£89.60 Ex VAT
Add to Cart
762REUR-00
Eaton Security
(image for) Eaton 2-Channel Narrow Band Wireless Receiver
762 2-Channel standalone Receiver The 762 2-channel stand alone receiver enables you to see at a glance the status of up to two remote...
£186.51 Ex VAT
Add to Cart
