Elmdene 5.0 Amp Output, plus battery charging. Box size B
High efficiency, cost effective range of Switch Mode power supplies for use in Access Control, CCTV and General Purpose applications. Modular construction provides for easy maintenance and upgrade capability.
Featuring a regulated highly stable output supplying a full rated current to load and a universal mains voltage input (90 to 264 Volts a.c.)
Switch Mode 12 Volt dc Power Supply Units
The Range Consists of 10 Models:
  • G13801N-A     1.0A
  • G13802N-A     2.0A
  • G13802N-C     2.0A
  • G13803N-A     3.0A
  • G13803N-B     3.0A
  • G13803N-C     3.0A
  • G13804N-B     4.0A
  • G13804N-C     4.0A
  • G13805N-B     5.0A
  • G13805N-C     5.0A
'G-N' Series Features:
  • Full Rated Current to Load + 0.5A battery charging
  • Universal Mains Voltage Input 90V – 264V ac
  • Electronic Overload Protection
  • Mains Transient Protection
  • Front Tamper Protection
  • Mains Status LED Indication
Specifications:
Output (mains on) 13.6 – 14.2V dc nominal
Load Output 1,2,3,4 & 5 Amp
Max Battery Capacity 'A' Box: 1 x 7Ah. 'B' & 'C' Box 1 x 17Ah - not supplied
Mains Supply 90 – 264V a.c. @50-60Hz
Environment -10C to 40C @ 95%RH
Enclosure:
A 200Hx230Wx80D hinge lid
B 330Hx355Wx80D clam lid
C 275Hx330Wx80D hinge lid
  • Model: G13805N-B
  • Manufactured by: Elmdene
£79.00 Ex VAT
