Elmdene Flush Mounted Stainless Steel 16 Ohm Extension Speaker
Elmdene Flush Mounted Stainless Steel 16 Ohm Extension Speaker - Tampered
Elmdene’s new range of flush extension speakers have been designed to be used with all common Intruder panels. Offering a more aesthetic look compared to standard types, they are available in two finishes:
  • White Plastic
  • Brushed Stainless Steel
Offered in a single gang format they will fit on either a flush mounting steel box or a standard surface box.
Both plates are supplied with an optional rear tamper switch, monitoring for plate removal if required. Speakers are rated at 16 Ohms impedance making them compatible with all common control panels.
The devices use modern, stylish face plates which can be screen printed with a company logo if required (MOQ applies).
• Flush or surface mount
• Single gang size (86mm x 86mm)
• [White plastic option]
• Provided with 16 Ohm speaker
• Tampered
• Provided with plate screws (30mm length)
• Aesthetically pleasing design
• Environmental class II
• Provided with termination blocks for speaker & tamper connections
• Screen printing available on all models
• 3 year warranty
  • Model: EXTSP-16T-SS
  • Manufactured by: Elmdene
£18.10 Ex VAT
