Elmdene
Displaying 1 to 12 (of 192 Products)
VR241000EB
Elmdene
(image for) Elmdene 24v Encapsulated 1 A PSU
ELMDENE VR241000EB 24VAC 1AMP PSU
£19.97 Ex VAT
Add to Cart
E16ABARGAINBUCKET
Elmdene
(image for) Elmdene E16A Safe Limpet With Keep
    H130mm x W105mm x D30mm Features Inertia vibration detector Thermal Sensor Safe proximity Sensor
£64.00 Ex VAT
Add to Cart
INT400S
Elmdene
(image for) Elmdene INT400S Internal SAB
he Inter range of polycarbonate sounders is available in three versions: high and/or low level sounders with or without strobe. All versions can be...
£18.58 Ex VAT
Add to Cart
POE-MINIPOD
Elmdene
(image for) Elmdene - PoE Mini Pod
Power Over Ethernet (PoE) New to Elmdene's power supply range are Power Over Ethernet (PoE) standby devices. These units are capable of providing...
£116.22 Ex VAT
Add to Cart
POE-POWERPOD
Elmdene
(image for) Elmdene - PoE PowerPod 8 way PoE
£958.59 Ex VAT
Add to Cart
2401-C
Elmdene
(image for) Elmdene 1.0Amp 24v Power Supply
The 'Standard' range of power supplies has been specifically designed for General Purpose applications including Fire and Access Control that...
£47.34 Ex VAT
Add to Cart
GEN3-34-R
Elmdene
(image for) Elmdene 12v 3 amp GEN range PSU (13.8v)
The GEN series of switch mode power supplies has been specifically designed to provide a comprehensive and flexible range for engineers designing...
£139.98 Ex VAT
Add to Cart
G13801N-A
Elmdene
(image for) Elmdene 12v DC 1 amp PSU G13801N-A
High efficiency, cost effective range of Switch Mode power supplies for use in Access Control, CCTV and General Purpose applications. Modular...
£23.66 Ex VAT
Add to Cart
VRS122000-PTC-P
Elmdene
(image for) Elmdene 12v dc CCTV PSU
Product Overview   A switch mode power supply unit providing 12V dc (2A max) in a compact IP66 rated enclosure, ideal for CCTV applications. ...
£24.61 Ex VAT
Add to Cart
G13802BMU
Elmdene
(image for) Elmdene 12VDC 2 Amp Switch Mode Unboxed PSU
12VDC Switch Mode PSU (13.8V) 2Amp to load + 0.5A battery charging. Battery Monitoring, Efficient Switch Mode operation. Multi LED status...
£43.83 Ex VAT
Add to Cart
G13805BM-B
Elmdene
(image for) Elmdene 13.8V dc G-Range BM Series 5.0A G13805BM-B
Product Overview The G Range BM Series switch mode power supplies are ideal for applications requiring mains and battery monitoring. The units have a...
£92.38 Ex VAT
Add to Cart
G13805BM-C
Elmdene
(image for) Elmdene 13.8V dc G-Range BM Series 5.0A G13805BM-C
£85.83 Ex VAT
Add to Cart
