Elmdene Switch Mode 12v dc 2.0a PSU
Product is obsolete.
12V G Range BM Series
High efficiency, cost effective range of Switch Mode power supplies featuring Mains and Battery Monitoring with two independent volt free fault outputs, for use in Access Control, CCTV and General Purpose applications. Modular construction provides for easy maintenance and upgrade capability.
Boxed and Unboxed Models
Featuring a regulated highly stable output supplying a full rated current to load and a universal mains voltage input (90 to 264 Volts a.c.)
Switch Mode 12 Volt dc Power Supply Units
The Range Consists of:
·          G13801BM-A1.0A
·          G13801BM-B1.0A
·          G13801BM-C1.0A
·          G13801BMU1.0AUnboxed  152L x 106W x 52D
·          G13802BM-A2.0A
·          G13802BM-B2.0A
·          G13802BM-C2.0A
·          G13802BMU2.0AUnboxed  152L x 106W x 52D
·          G13804BM-B4.0A
·          G13804BM-C4.0A
·          G13805BM-B5.0A
·          G13805BM-C5.0A
·          G13810BM-8-C10.0A(2x 5A modules with 2x 4 way fused outputs)
 'G' Range 'BM' Series Features:
  • Efficient Switch Mode Operation
  • Closely Regulated 13.8V Output
  • Full Rated Current to Load + 0.5A battery charging
  • Boxed and Unboxed Models with DIN Rail Mount Option 1 & 2A
  • Universal Mains Voltage Input 90V – 264V ac
  • Mains and Battery Monitoring
  • Deep Discharge Protection
  • Electronic Overload Protection
  • Volt Free Fault Output - 1
    • Mains Fail
  • Volt Free Fault Output – 2
    • Battery Failure
    • Output / Battery Fuse Failure
    • Output Short Circuit
  • Mains Status LED Indication
    • Mains Status
    • Output Fuse Fail
    • Battery Low or Missing
  • Mains Transient Protection
  • Front Tamper Protection
Specifications:
Output (mains on)13.8 dc nominal
Load Output1, 2, 4, 5 & 10 Amp
Max Battery Capacity'A' Box 1 x 7Ah, 'B' & 'C' Box 1 x 17Ah
10A Model: 2 x 7Ah (batteries not supplied)
Mains Supply90 - 264V a.c. @50-60Hz
Environment-10C to 40C @ 95%RH
Enclosure:
A      200H x 230W x 80D - hinge lid
B      330H x 355W x 80D - clam lid
C      275H x 330W x 80D - hinge lid
  • Model: G13802BM-B
  • Manufactured by: Elmdene
£63.36 Ex VAT
