ERA 100 Patio Door Lock -White
Patio Door lock suitable for fitting at top or bottom of wooden, metal and PVCu sliding patio doors. Simple to fit with all required screw supplied and full fitting instructions, also easy to use with straightforward push to lock and key to unlock. This high quality patio lock from ERA features hardened steel pin in the bolt which resists hacksawing and supplied with a ferrule to finish the drilled door frame.
Finish: White and [Grey]
Body Size: 46 x 27 x 26mm
Keys Supplied: 2
Pack Quantity: 1
 Suitable for most types of wooden, aluminium and UPVC sliding patio doors. Supplied with fixing screws
Operation: Push bolt to lock. Released by use of key.
  • Model: L307
£29.52 Ex VAT
