Fike
Displaying 1 to 12 (of 58 Products)
302 0001
Fike
(image for) Fike Hatari Sounder RED
The twinflex hataris is designed to comply with the European Standard EN54 part 3. The stand alone Hatari sounder can be utilised where extra sound...
£13.49 Ex VAT
Add to Cart
302 0002
Fike
(image for) Fike Hatari Sounder White
£13.49 Ex VAT
Add to Cart
507 0001
Fike
(image for) Fike 1-4 Loop Quadnet Control Panel and PSU
OBSOLETE - Alternative CLICK HERE   The Quadnet panel supports four plug-in loop cards, giving choice for the size of system requirements....
£900.26 Ex VAT
... more info
604 0002
Fike
(image for) FIKE 2 Zone TWINFLEXpro Fire Alarm Kit with ASD Detector
Alternative for [6030002] FIKE 2 Zone TWINFLEXpro Fire Alarm Kit with ASD Detector & Call Points (604-0002) FIKE Kit Incldues:...
£456.73 Ex VAT
Add to Cart
604 0004
Fike
(image for) Fike 4 Zone TWINFLEXpro Fire Alarm Kit with ASD Detector
FIKE, 604-0004, 4 Zone TWINFLEXpro Fire Alarm Kit with ASD Detector and Call Points FIKE Kit Incldues: 1 x TwinflexPro 4 Zone Fire Panel7 x...
£496.22 Ex VAT
Add to Cart
905 0001
Fike
(image for) Fike ASD Detector Mounting Base PK 5
Mounting bases for Sita Multipoint ASD detector. Complete with srping loaded shorting link to give positive core continuity when detector removed....
£9.91 Ex VAT
Add to Cart
25-0046-201
Fike
(image for) Fike ASD Head Removal Tool
The Head Removal Tool makes maintenance of systems simple. A necessity for maintenance, the Head Removal Tool is supplied free of charge with any...
£9.23 Ex VAT
Add to Cart
900 0003
Fike
(image for) Fike ASD White Deep Base Back Box
Fike ASD deep base for surface installations. The 900-0003 is a deep back box which is suitable for surface mount cable termination of cables with...
£3.49 Ex VAT
Add to Cart
45-0022-S
Fike
(image for) Fike Call point Test Key
Fike Test Key for Call Points
£0.78 Ex VAT
Add to Cart
540-0001
Fike
(image for) Fike CIE-A-400 2 Loop Addressable Fire Alarm Control Panel
The CIE-A-400 Addressable Fire Alarm Control Panel is a two loop panel capable of each loop supporting up to 200 devices with a maximum loop length...
£631.41 Ex VAT
Add to Cart
205 0003
Fike
(image for) Fike Multipoint Addressable Asd Detector With Sounder
ADDRESSABLE MULTIPOINT ASD DETECTOR/SOUNDER DESCRIPTION The Addressable Multipoint ASD is a plug-in type smoke detector that utilizes a...
£24.05 Ex VAT
Add to Cart
507 0030
Fike
(image for) Fike Quadnet and Duonet Loop Card 507-0030
Quadnet and Duonet loop card, for expanding the number of loops on a panel and for replacement purposes
£201.10 Ex VAT
Add to Cart
