GE Security
Displaying 1 to 12 (of 36 Products)
DB702
GE Security
GE Security
Aritech 10 cm Diameter Detector Base - 6 terminals
10 cm diameter base for [DP721R] - 6 terminals Preventing false alarms with self diagnostics All Aritech 700 series smoke detectors continuously...
£4.06 Ex VAT
Add to CartATS1135
GE Security
GE Security
Aritech Advisor Advanced Residential Keypad
Description ATS1135 Advisor Advanced Residential keypad with built-in reader The ATS1135 offers a stylish design providing for clear and readable...
£66.83 Ex VAT
Add to CartDP721RT
GE Security
GE Security
Aritech DP721RT, Photoelectric Smoke and Heat Detector
Aritech DP721RT, Photoelectric Smoke and Heat Detector with Relay Output All Aritech 700 series smoke detectors continuously monitor their...
£44.00 Ex VAT
Add to CartGS610-W
GE Security
GE Security
The GS610/612 shock senors offers a versalite solution for detection of forced entry through windows, doors, walls and roofs. They can be mounted...
£27.76 Ex VAT
Add to CartGS612B
GE Security
GE Security
Aritech GS612 Brown Shock Sensor
The GS612B shock sensor offers a versatile solution for detection of forced entry through windows, doors, walls and roofs. It can be mounted...
£13.71 Ex VAT
Add to CartGS612
GE Security
GE Security
The GS612 shock sensor offers a versatile solution for detection of forced entry through windows, doors, walls and roofs. It can be mounted...
£13.71 Ex VAT
Add to CartGS710-white
GE Security
GE Security
The GS710 shock sensor offers a versatile solution for detection of forced entry through windows and doors. It can be mounted throughout a 360...
£32.69 Ex VAT
Add to CartGS611A
GE Security
GE Security
Aritech Inertia shock sensor - White
Inertia shock sensor designed for use with 10 to 15 VDC analyzer modules, with reed switch, white. The GS600 series sensors are highly reliable shock...
£33.25 Ex VAT
Add to CartDP721R
GE Security
GE Security
Aritech Photoelectric Smoke Detector with c/o relay output
DP721R - 700 Series Conventional Optical Smoke Detector w/ Relay Output Description The DP721R is an optical smoke detector with field exchangeable...
£51.72 Ex VAT
Add to CartGS710B
GE Security
GE Security
GS710B, Shock Sensor (Brown) The GS710 shock sensor offers a versatile solution for detection of forced entry through windows and doors. It can be...
£16.16 Ex VAT
Add to CartGS614
GE Security
GE Security
Aritech Single Zone Shock Analyzer
The Sentrol GS614 and GS615 Shock Sensor Analyzers work in conjunction with the inertia shock sensors GS600, GS610, & GS611. The analyzer is...
£29.33 Ex VAT
Add to CartGS615-W
GE Security
GE Security
Aritech Single Zone Shock Sensor Analyzer
Shock Sensor Analyser The single multi count analyser has an amplitude setting which allows the installer the flexibility of adjusting the level of a...
£29.33 Ex VAT
Add to CartDisplaying 1 to 12 (of 36 Products)
