GJD 4 Zone Expansion Unit
This energy efficient 4 zone expansion unit couples with the DygiZone digital lighting controller to extend your lighting circuits, allowing them to cover a wider area.
Designed to work GJDs DygiZone enunciator external PIR detectors, the advanced 4 Zone Expansion Unit greatly simplifies installation time and cost.
The 4 Zone Expansion Unit incorporates an energy efficient switched mode power supply and can control up to four individual lighting circuits each with 1500W resistive load.
  • Works in conjunction with GJD DygiZone
  • Modular design
MAINS SUPPLY INPUT 2 X 230 VAC 50Hz via RCD, MCB & 13 AMP fused spurs
LIGHTING OUTPUTS DRIVEN 4 X 230 VAC 50Hz 1500 WATTS resistive maximum or 1000 watts ballast
12 VDC DRIVEN 12 VDC @ 1 AMP
“T” 1 & 2 OUTPUT 5 mA +VE suitable for driving base of NPN transistor. Triggered from detectors on zones 1&2
“T” 3 & 4 OUTPUT 5 mA +VE Suitable for driving base of npn transistor. Triggered from detectors on zones 3 & 4
AUX 1 & 2 OUTPUT 50 Ma -VE suitable for driving low power sounders. Triggered from detectors on zones 1 & 2
AUX 3 & 4 OUTPUT 50 Ma -VE suitable for driving low power sounders. Triggered from detectors on zones 3 & 4
OPTIONS Up to 10 expansion units can be added to a system for additional switching capacity or 12 volt supply
OPERATING TEMPERATURE -10 to 50ºc
WEIGHT 810g
DIMENSIONS 210 x 180 x 79mm
MOUNTING Mount in a clean dry location on a secure flat surface
  • Model: GJD040
  • Manufactured by: GJD
£86.43 Ex VAT
