GJD Mini Opal External 30m PIR
Adjustable up to 30m, this mini motion detector packs a powerful punch in a small package. Designed for outdoor use with GJD lighting controllers
An adjustable range PIR with front and rear tamper switches and sliding curtains to aid installation and field of view alignment. Modelled after the modern and stylish look of the D-TECT range of detectors.
GJD Mini Opal detectors are designed for outdoor use in conjunction with GJD’s lighting controllers and enunciators.
  • White light filter
  • Dual tamper switch for case and wall-mount tamper protection
  • Sliding curtains for precise coverage ±90º horizontal and ±45º vertical aim adjustment
  • Conformally coated electronics for enhanced UV and moisture resilience
Coverage (max)90° at 30m, equivalent to 625m²
RangeAdjustable 8m to 30m
Directional adjustment±90° horizontal (180°), ±45° vertical
Area adjustment (blanking)Supplied with,1 foil label for near/ far beam blanking and 4 vertical opaque curtains for zone blanking
Lens2 rows of 10 beams
SensorWhite light filter prevents false triggering when sunny
Ouput A (Alarm)Open-collector transistor switch. 12V, 25mA alarm current.
Output S (Sensor, daylightOpen-collector transistor switch, 12V, 25mA alarm current
Output T (Tamper)Volts-free, normally-open switch output
Tamper switchesCase open and removal from wall
Power9 to 15V DC
Current4mA at 12V
Operating Temperature-20°C to +55°C
ProtectionIP55, high-impact ABS housing, Conformal coated electronics (moisture and UV protection lacquer)
Dimensions84 x 106 x 72 mm
MountingSuggested height 3m
Cabling0 to 200m: standard, 4-core, 7.0.2mm alarm cable 200 to 500m: 8-core, 16/0.2mm (use double cores)
  • Model: GJD332
  • Manufactured by: GJD
£53.83 Ex VAT
