Guardall
Displaying 1 to 11 (of 11 Products)
VE1120AM
Guardall
(image for) Aritech VE1120AM, 20M PIR Volumetric Detector with Active IR
VE1120AM, 20M PIR Volumetric Detector with Active IR Anti-Mask (11 Curtains) Our motion sensors have the most advanced and sophisticated optics in...
£72.23 Ex VAT
Add to Cart
W76555
Guardall
(image for) Guardall 15m Quad PIR
PQ15 is one of Guardall’s new Passive Infra-red detectors within the detector platform range. Varifocal optics and advanced digital signal...
£44.00 Ex VAT
Add to Cart
W76561
Guardall
(image for) Guardall DT15 Dual Technology Detector
The Performance Line is the line of legacy Guardall motion sensors (PQ15 and DT15 series) and both are intended for the protection of residential and...
£31.64 Ex VAT
Add to Cart
W76558
Guardall
(image for) Guardall PQ15 AM 15m Antimask Movement Detector Grade 3
Obsolete available while stocks last Alternative click here PQ15 AM - • 15m/10m volumetric PIR detector Through-the-lens active IR anti-masking...
£32.48 Ex VAT
Add to Cart
W73820
Guardall
(image for) Guardall W73820 PK of 2 Fobs
*please be advised these fobs will only work with ; Keypads with reader having firmware V3.0 or later operate properly (Batchcode 0700 and later) ...
£14.70 Ex VAT
Add to Cart
W74480
Guardall
(image for) Guardall 8 Input Zone Expander
OBSOLETE - No longer available   Guardall W74480   Expander 8 Input Housed in plastic casing 8 inputs 4 outputs Compliant with Grade 3,...
£67.88 Ex VAT
... more info
W74065
Guardall
(image for) GUARDALL W74065 M2
GUARDALL W74065 M2
OBSOLETE - Alternative Click Here   Guardall M-2 Retaining the elegant and distinctive styling of the successfully  innovative Guardall...
£16.20 Ex VAT
... more info
W76329
Guardall
(image for) Guardall 8 Inputs Concentrator with Power Supply 3A
OBSOLETE - No longer available   Guardall, W76329, 8 Inputs Concentrator with Power Supply 3A Key Features: 8 inputs with NC or EOL diagnostic...
£160.16 Ex VAT
... more info
W73526
Guardall
(image for) Guardall W73526 V12
Guardall W73526 V12
£35.61 Ex VAT
... more info
W76250
Guardall
(image for) Guardall G3 LCD keypad
OBSOLETE - No longer available Keypad with CCTS & Proximity •32 character backlit display •Single programmable output •Two End-Of-Line...
£106.80 Ex VAT
... more info
W72321
Guardall
(image for) Mountable Bracket for Guardall DT, PQ (Platform) & DTX detectors
OBSOLETE - No longer available   Brackets are mountable on the wall and enable easier adjustment of the detector angle.
£5.88 Ex VAT
... more info
