Haydon
Displaying 1 to 10 (of 10 Products)
HAY-IP-24VPSU-1X4A
Haydon
(image for) Haydon IP66 Rated External PSU 1 X 4a Outlet
IP66 Rated External PSU 1 X 4A Outlet
£49.99 Ex VAT
Add to Cart
HAY-PSU1612-20A
Haydon
(image for) Haydon 16 Way 20A Metal Boxed PSU
The new range of multi way metal boxed PSUs from Haydon are now available in 6 units. They are all 12vDC units in the following options 4 Way x...
£69.98 Ex VAT
Add to Cart
HAY-PSU8/1-1/8A 24V
Haydon
(image for) Haydon Dual Output 8 x 1A or 1x 8A 24VAC
Haydon’s range of multi way metal cased PSUs use the latest technology PTC fuses, eliminating replacing fuses after overvoltage or short...
£56.99 Ex VAT
Add to Cart
HAY-PSUMULTI-10A
Haydon
(image for) Haydon HAY-PSUMULTI-10A -12v 10Ah 16 Way Box Power Supply
Professional 12v 10Ah metal box PSU with 16 outputs, each output is PTC fused offering individual protection to each camera.   PTC protection is...
£46.90 Ex VAT
Add to Cart
HAY-HDVB01POC-PT
Haydon
(image for) Haydon POC Video Balun Pack 2
Single Channel POC Video Balun for HD-TVI, CVI, AHD & CVBS and POC Analogue camera, with built in strain relief feature. This replaces the...
£6.32 Ex VAT
Add to Cart
HAY-POE-MULTI
Haydon
(image for) Haydon POE Multiplexer Pack of 2
· Run two Cameras/Network Devices across a single CAT 5/6 cable up to 100 metres   · Simple plug & play installation with...
£12.00 Ex VAT
Add to Cart
HAY-PSU412-5A
Haydon
(image for) Haydon 4 Way 5A Metal Boxed PSU
OBSOLETE - No longer available   The new range of multi way metal boxed PSUs from Haydon are now available in 6 units. They are all 12vDC...
£36.50 Ex VAT
... more info
HAY-PSU912-10A
Haydon
(image for) Haydon 9 Way 10A Metal Boxed PSU
OBSOLETE - Alternative CLICK HERE   The new range of multi way metal boxed PSUs from Haydon are now available in 6 units. They are all...
£43.50 Ex VAT
... more info
HAY-PSMULTI-5A
Haydon
(image for) Haydon 9 Way 5A Boxed Power Supply
OBSOLETE - No longer available   HAY-PSUMULTI-5A Haydon metal boxed 12VDC 5A power supply for CCTV cameras supports up to 9 outputs with a...
£25.99 Ex VAT
... more info
HAY-PSU1612-10A
Haydon
(image for) Haydon HAY-PSU1612-10A, 16 Way Boxed PSU 10 Amp
OBSOLETE - Alternative CLICK HERE   HAY-PSU1612-10A, 16 Way Boxed PSU 10 Amp PTC Fuses Surge Protected When traditional fuses are being...
£49.99 Ex VAT
... more info
