Honeywell Thermal Smoke Detector
The ECO1005 A detector is a rate of rise sensor, which uses a state of the art thermal element combined with an application specific integrated circuit (ASIC) to provide quick and accurate detection of fires.
The detector incorporates both rate of rise and static elements and is suitable for all areas where the ambient conditions do not normally exhibit rapid changes in temperature.
The ECO1005 A  has an integral LED, which illuminates to provide a local alarm signal. This latches on and remains illuminated until the detector is reset by a momentary power interruption. An optional remote LED annunciator may be used to repeat any alarm signal.
Features & Benefits:
  • Low profile design
  • Low current draw
  • Automatic drift compensation
  • Remote alarm test feature
  • Easy maintenance
  • Remote LED Option
Certifications:
  • 2831-CPR-F1878 for EN54-5:2000+2002 Class AIR1
  • 2831-MED-1019 Module B
  • 2831-MED-1020 Module D
  • G201016
  • Detection Sensor Type : Photoelectric
  • Brand : Honeywell Security
For 12v use this product requires a base: click here
  • Model: ECO1005-A
  • Shipping Weight: 0.3 kgs
  • Manufactured by: Honeywell
£19.63 Ex VAT
