Description
Galaxy Dimension GD-96 control panel with PSTN Dialler is a hybrid intruder control panel with integrated door control functionality. It is designed for mid to large commercial installations and is fully compliant to the latest PD6662:2010 and EN50131 standards
- Up to 96 zones
- Up to 64 doors controlled
- Protecting up to 32 groups
- Up to 1000 users
- Up to 67 weekly schedules available
- Up to 32 yearly holiday schedules
- Door access controlled by access templates and group set status
- Areas behind a door can be unset automatically via card reader
- Access event log with 1000 events recorded in panel (separate intruder log)
- GPRS, Ethernet, PSTN, USB communications options
- Groups can be set via door control readers
- Evacuation control will allow doors to unlock in the event of fire
- Up to 32 audio verification channels
- Multi-language interface
- The Galaxy Dimension range has been independently tested and is compliant to EN50131-3:2009, EN50131-6:2008, PD6662:2010
- Compatible with all wiegand readers
- Up to 8 wireless interface modules (RF portals)
- Up to 192 wireless zones
- Up to 100 key fobs
- Full bi-directional agile routing (patented technology)
- Full range of wired and wireless intrusion and environmental detectors
The Galaxy® Dimension series of security systems is a fully integrated intrusion and door control security solution for mid to large commercial security installations. It offers your customers a user-friendly system in a cost-effective and fully compliant Security Grade 3 package. With innovative wireless capability and user-friendly remote management options, the series provides high quality, reliable security solutions, with the flexibility to meet the needs of every commercial and industrial application.
Flexible & reliable communications
To ensure fail-safe communications, multiple path communication options for alarm signalling include GPRS, Ethernet and standard telephone line (PSTN). These options also allow maximum flexibility and customisation to capitalise on existing network infrastructures and minimise disruption for customers.
Attractive user interfaces and Mobile App
A choice of LCD Keypad and Keyprox options including the MK8, with a modern design and all the familiarity and functionality of the MK7, for ease of programming across the range. In addition, all user interfaces feature a proximity function allowing quick and secure set and unset without PIN code. The GX Remote control mobile App allows control of the system from anywhere in the world from your preferred smart device (requires E080-04 Ethernet module).
Audio verification (‘Listen-in’ Facility)
With Galaxy® Dimension, an Alarm Receiving Centre (ARC) can listen in using independant audio channels to identify the specific location where the alarm has been triggered and verify source and cause. This reduces false alarms and increases system reliability.
Programming software compatibility
The Remote Servicing Suite (RSS) is a maintenance tool enabling complete remote control of the panel, allowing installers to give customers instant support. Installers can complete remote routine inspection reducing the need for time consuming and costly site visits. The RSS software uses a common database to communicate with all Galaxy® panels from one programme. A networked version of the Remote Servicing Suite offers access to up-to-date records for all users. This guarantees the secure management of information in one central location. Both wired and wireless components can take advantage of the easy remote diagnostics and maintenance functionality in this software.
Secure wireless options
Cabling can be impractical due to building aesthetics, or simply too expensive. By removing cabling, particularly from large installations, significant time can be gained, costs saved and disruption to customer’s operations can be minimised. Galaxy Dimension is a hybrid control panel series that offers wired, wireless or a combination of both solutions and uses patented control panel software and bi-directional radio and agile routing technologies to provide secure and reliable security for commercial environments. A combination of up to eight RF portals per installation, a wide range of intruder, perimeter, environmental and life safety wireless sensors which boast a 2km radio range (in open field) ensures the strongest signal path is used to keep control panel and sensors in constant communication and provides a flexible and customisable system to meet business needs.
Remotely manage sites and save time and money
The introduction of WIN-PAK for Galaxy end user software brings a new level of ease to managing up to five Galaxy systems simultaneously across multiple sites, from one central location. Designed to ease user management, the software manages user names, PINs, authority rights across sites, it automatically updates one or more Galaxy panels and allows users to be added and deleted in just a few mouse clicks. Improved command and control is achieved through specific Galaxy floor plans that clearly display alarms and other information which along with reporting and automation features provides users with a highly secure, powerful management tool that can be expanded to meet your security needs.
Fully managed and monitored integrated solutions
When the time is right, with WIN-PAK, the system can be expanded to include fully featured access control (NetAXS) and further expanded to a full management and monitoring system that includes multiple intruder systems, access control and CCTV surveillance all controlled by WIN-PAK.
Technical Specifications
Description |
GD-48 |
GD-96 |
GD-264 |
GD-520 |
Zones onboard (maximum)
Inclusive wireless zones
16 - (48)
32
16 - (96)
80
16 - (264)
192
16 - (520)
192
Outputs (400mA) on-board |
8 |
8 |
8 |
8 |
Trigger outputs on flying lead (10mA) |
6 |
6 |
6 |
6 |
Integrated PSU |
2.5A |
2.5A |
2.5A |
2.5A |
Output Current rating |
1.2A |
1.2A |
1.2A |
1.2A |
RS485 Databuses |
1 |
2 |
2 |
4 |
Keypads (Keyprox) |
8 (3) |
16 (7) |
16 (7) |
32 (24) |
Bus mounted prox readers (MAX) |
4 |
16 |
16 |
32 |
DCMs with 2 x Wiegand interfaces |
4 |
16 |
16 |
32 |
DCM controlled doors |
8 |
32 |
32 |
64 |
Wireless Portals |
4 |
8 |
8 |
8 |
Users |
100 |
250 |
1000 |
1000 |
7 Day Timer Schedules |
19 |
35 |
67 |
67 |
Zone types |
52 |
52 |
52 |
52 |
O/P types |
81 |
81 |
81 |
81 |
Library |
Yes |
Yes |
Yes |
Yes |
Event Log |
1000 |
1500 |
1500 |
1500 |
Access Log |
500 |
1000 |
1000 |
1000 |
Multi-users |
Yes |
Yes |
Yes |
Yes |
Autoset |
Yes |
Yes |
Yes |
Yes |
Pre-Check |
Yes |
Yes |
Yes |
Yes |
Timed Lockout |
Yes |
Yes |
Yes |
Yes |
Links |
64 |
128 |
256 |
256 |
Part Set |
Yes |
Yes |
Yes |
Yes |
Silent Part Set |
Yes |
Yes |
Yes |
Yes |
RS232 |
Built-in |
Built-in |
Built-in |
Built-in |
Integrated PSTN (V 22) |
Built-in |
Built-in |
Built-in |
Built-in |
Printer Output |
Via RS232 |
Via RS232 |
Via RS232 |
Via RS232 |
Remote Servicing |
Yes |
Yes |
Yes |
Yes |
Ethernet module |
Optional |
Optional |
Optional |
Optional |
GSM/GPRS module |
Optional |
Optional |
Optional |
Optional |
Groups |
8 |
16 |
32 |
32 |
Audio Verification channels |
8 |
16 |
32 |
32 |
SMS text |
Yes |
Yes |
Yes |
Yes |
Mobile App* |
Yes |
Yes |
Yes |
Yes |
* Requires E080-04 Ethernet module
