Trimec Tb38 Fail Open Solonoid Bolt
The TB38 range of drop bolts represent true engineering innovation, design excellence and the superior quality customers have come to expect and demand from Padde.
Designed for use on swing-through, double action doors, these drop bolts are ideal for applications where an electric strike is impractical.
High Security. Bolt is deadlocked in the extended position Bolt position monitored Door position monitor with integrated magnet into the strike plate (no need to install a separate reed switch)
Multiple Orientation, drop bolts will work horizontally or vertically Power to Lock/ Power to Open Continuously Rated Solenoid Tamper Proof.
Lock cannot be defeated by slipping a metal object between lock and striker plate Intelligent Electronics.
These intelligent bolts will attempt to re-close the bolt 8 times, allowing time for swing through doors to settle in the closed position Thermal Protection. In the event of solenoid overheat, a thermal fuse will operate, eliminating any fire risk
Applications
Misaligned doors
Timer Doors
Standards and Compliance
British Standard BSEN 50081-1 & BSEN 50082-1 CE Approved C-tick Certified
  • Model: 188381-010
  • Shipping Weight: 4 kgs
  • Manufactured by: IEC Trimec
£520.15 Ex VAT
