Interface Solutions
Displaying 1 to 6 (of 6 Products)
ISM12
Interface Solutions
Interface Solutions
Interface Solutions 12 volt Mini Polarised Relay
This is the miniature version of the IS 12 volt relay. It is a double pole relay complete with LED indication. It is supplied in a strip of 4 modules...
£9.79 Ex VAT
Add to CartIS12
Interface Solutions
Interface Solutions
Interface Solutions 12 volt Polarised Relay
The 12 volt double pole relay is a simple to fit module wherever a dry contact, voltage free switching is required or where there is a need for...
£8.50 Ex VAT
Add to CartISM12T
Interface Solutions
Interface Solutions
Interface Solutions ISM12T 12 Volt Mini Transistor Relay
This is the transistorised miniature version of the IS 12. It is a double pole relay complete with LED indication. It has been designed to allow low...
£11.76 Ex VAT
Add to CartIS-24
Interface Solutions
Interface Solutions
IS 8A Double Pole 24v Polarised Relay
The 24 volt double pole relay is a simple to fit module wherever a dry contact, voltage free switching is required or where there is a need for...
£11.00 Ex VAT
Add to CartISAC/DC
Interface Solutions
Interface Solutions
The IS AC/DC relay is a very versatile relay as it will operate on AC voltages ranging from 6 volts to 32 volts, and it will also operate on DC...
£12.84 Ex VAT
Add to CartIS BF
Interface Solutions
Interface Solutions
IS Alarm DSL Filter/Broadband Filter
The Z-A431EU alarm panel DSL filter is designed to eliminate the interference that occurs with alarm systems and ADSL service, and that often...
£24.80 Ex VAT
Add to CartDisplaying 1 to 6 (of 6 Products)
