Klaxon
Displaying 1 to 12 (of 15 Products)
SLE-0002
Klaxon
(image for) Klaxon 103dB 24V DC 500mA Mini Master Blaster Siren
OBSOLETE - Alternative Click here   The Mini Mono P is a small motor driven siren designed for fire and general alarm signalling. Designed for...
£48.91 Ex VAT
... more info
SLD-0001
Klaxon
(image for) Klaxon 127Db 110v High Output Master Blaster Low Voltage Siren
*Special order item, delivery 5-7 working days P-Series Master Blaster The Master Blaster is a powerful motor driven siren designed for use as an...
£128.04 Ex VAT
Add to Cart
SLM-0001
Klaxon
(image for) Klaxon 127Db 230v High Output Master Blaster Siren (12v Relay)
P-Series Master Blaster The Master Blaster is a powerful motor driven siren designed for use as an internal/external supplementary security sounder....
£105.69 Ex VAT
Add to Cart
SLD-0002
Klaxon
(image for) Klaxon 127Db High Output Master Blaster 240v Siren
£140.64 Ex VAT
Add to Cart
306823
Klaxon
(image for) Klaxon Flashguard Value back plate
Premier live back plates have 2 sounder units, making them louder, and a larger back up battery than the Value live back plates, which have a single...
£22.30 Ex VAT
Add to Cart
PSC-0042
Klaxon
(image for) Klaxon Sonos Electronic Sounder Beacon
Sonos Sounder Beacon Electronic sounder beacon certified to EN54. With the TimeSaver base, connections are made to the base during the initial...
£27.07 Ex VAT
Add to Cart
PSS-0050
Klaxon
(image for) Klaxon Sonos Sounder Only- White Body Deep Base 9-60v DC
  Klaxon Sonos Sounder Only, White Body, Deep Base 9-60v DC - PSS-0050 (18-980476) This product is a general purpose electronic sounder....
£14.50 Ex VAT
Add to Cart
SLD-0002+HLR24+Secwarebox1
Klaxon
(image for) Klaxon 127Db 240v High Output Master Blaster Siren (24v Relay)
 P-Series Master Blaster The Master Blaster is a powerful motor driven siren designed for use as an internal/external supplementary security...
£124.16 Ex VAT
Add to Cart
18-980044
Klaxon
OBSOLETE - Alternative Click Here   P-Series Master Blaster The Master Blaster is a powerful motor driven siren designed for use as an...
£89.71 Ex VAT
... more info
FDV--176
Klaxon
(image for) Klaxon Flashguard Flashguard XL White/Blue Cover
OBSOLETE - No longer available   XL Cover to suit Vertical Flashguard Backplates
£6.31 Ex VAT
... more info
42-504283
Klaxon
(image for) Klaxon Flashguard Premier Vertical Backplate, req Cover
OBSOLETE - No longer available V-Series With Flashguard V-Series Security Sounders you can pick your lid from a choice of three sleek designs and...
£33.20 Ex VAT
... more info
42-506039
Klaxon
(image for) Klaxon Flashguard V Series X-Pro Cover Red with Red Lens
OBSOLETE - No longer available   Xpro Cover Red & Opal Image differs to product as Lid Red with Red Lens
£6.50 Ex VAT
... more info
