Knight Manufacturing
Displaying 1 to 12 (of 108 Products)
D75MULTIB
(image for) Grade 2 Contact, 4 Terminal Single Reed Surface Contact+Tamper+Resistors, Brown
Grade: 2 Partcode: D75MULTIB A Grade 2 contact easily suited to most intermediate installations. Ideal for double door / shared zone use. D75MULTIB...
£3.83 Ex VAT
Add to Cart
J81
(image for) Knight 10 way Junction Box with TACT Tamper
TACT Spring Micro Switch Tamper Environmental Class 2 Material : ABS Colour: White Terminals : 8 + 2 Temp Range: -40C to 50C Tamper: TACT Spring...
£3.48 Ex VAT
Add to Cart
YF10C2M
(image for) Knight 2 METRE armoured cable Grade 3 roller shutter contact
Grade: 3 Partcode: YF10C2M Grade 3 Universal Handed Roller Shutter Contact 2 metres of Armoured Sleeving Magnetic Interference Detection and...
£29.77 Ex VAT
Add to Cart
A10
(image for) Knight 2-Terminal flush contact
Colour: White Environmental Class 2 Operating Gap: 14mm (approx) Dimensions: 20mm dia Terminals : 2- Screw Available while stocks last
£1.30 Ex VAT
Add to Cart
PA4W
(image for) Knight 4 Button Grade 3 Confirmable PA
IMPORTANT: DEVICE REQUIRES 12V SUPPLY AND 2 ZONES   G3 Electronic Confirmable PA 4-Button with LED and Selectable Resistors for all the main UK...
£15.82 Ex VAT
Add to Cart
E50
(image for) Knight 4 Core Single Reed Sealed Surface Contact (1m Fly)
Grade: 2 Partcode: E50 A small yet durable surface contact prefitted with 1m of 4 core fly lead. E50 provides protection against tampering and...
£2.26 Ex VAT
Add to Cart
D50
(image for) Knight 5 Screw Changeover Reed Surface Contact
Grade: 1 Partcode: D50 D50 is a 5 terminal surface contact. This particular variant includes a Changeover (C/O) reed. Of the 5 available screws, 2...
£3.62 Ex VAT
Add to Cart
A40B
(image for) Knight 5 Terminal Flush Contact - Brown
A40B 5-Terminal Flush Single Reed Contact (Quickfit) Colour: Brown Environmental Class 2 Operating Gap: 14mm (approx) Dimensions: 20mm dia Terminals...
£1.01 Ex VAT
Add to Cart
D20B
(image for) Knight 5 Terminal Surface Contact
D20 Brown 5-Terminal Single Reed Surface Contact White Colour: Brown Environmental Class 2 Operation Gap : 20mm Approx Dimensions: 67mm x 14mm x 13mm...
£1.25 Ex VAT
Add to Cart
D20BK
(image for) Knight 5 Terminal Surface Contact Black
D20 5-Terminal Single Reed Surface Contact Black Colour: Black Environmental Class 2 Operation Gap : 20mm Approx Dimensions: 67mm x 14mm x 13mm...
£4.20 Ex VAT
Add to Cart
D20GY-7016
(image for) Knight 5 Terminal Surface Contact Grey
Grade: 1 Partcode: D20GY-7016 A basic Grade 1, 5 terminal surface contact.  Two nickel screws to govern the reed switch and 3 spare brass screws...
£13.38 Ex VAT
Add to Cart
L905M
(image for) Knight 5M Armoured Door Loop c/w 2 off G3 JBs
Grade: 3 Model: L905M Grade 3 5 metre armoured sleeving Environmental Class 2 2 off Hinged Junction Box Impact strengthened Ideal for fitting on...
£24.16 Ex VAT
Add to Cart
