No Climb
Displaying 1 to 12 (of 18 Products)
SOLOC3-001
No Climb
(image for) No Climb Carbon Monoxide detector Tester
Genuine and non flammable CO stimulusNo flammable inappropriate hydrogenControllableSafeConvenient aerosol formatDetector manufacturer...
£18.20 Ex VAT
Add to Cart
SOLO101-001
No Climb
(image for) No Climb Solo 101 Extension Pole
Single section 1.13m / 3.5
£72.69 Ex VAT
Add to Cart
SOLO811-001
No Climb
(image for) No Climb Solo 811 Kit
*special order item please allow 5 working days from order.   A universal kit for removing, replacing and testing of smoke detectors up to 6...
£815.26 Ex VAT
Add to Cart
Solo 822-001
No Climb
(image for) No Climb Solo 822 Smoke & Cordless Heat Detector Test Set
*Special order item delivery approximately 3-4 weeks A universal kit for removing, replacing and testing of smoke and heat detectors up to 6 metres. ...
£1,003.29 Ex VAT
Add to Cart
SOLO823-101
No Climb
(image for) No Climb Solo 823 Smoke & Cordless Heat Detector Test Set 9.3 m
*Special order item, Delivery Approx 7 working days from order. Solo 823 Smoke & Cordless Heat Detector Test Set 9.3 metres Solo equipment is...
£2,112.12 Ex VAT
Add to Cart
6201-001
No Climb
(image for) No Climb Testifire 6201-001 Smoke, Heat and CO Detector Test Kit
***Special Order Item*** Testifire 6201-001 Smoke, Heat and CO Detector Test and Removal Kit - 6 Metres (20 ft) (Now Including High Capacity Battery...
£2,522.02 Ex VAT
Add to Cart
108-001
No Climb
(image for) Solo 108 Telescopic 2.5m Access Pole
Access poles are required for detectors out of normal reach. Their use saves the time, cost, disruption and risk to safety that ladders, scaffolding...
£158.87 Ex VAT
Add to Cart
330-001
No Climb
(image for) Solo 365 Smoke Detector Tester
Requirements for testing of smoke detectors vary by country, the common need is for a functional test where smoke, or simulated smoke, is introduced...
£179.99 Ex VAT
Add to Cart
SOLO727-001
No Climb
(image for) SOLO 727-001 Mains & Car Charger for SOLO Battery Batons
The Solo 727 charger enables fast charging of both the Solo 770 and 760 Battery Batons that are used to power the Solo 460, Testifire and Scorpion. ...
£117.25 Ex VAT
Add to Cart
SOLOA10-150
No Climb
(image for) Solo A10 150ml (Non-flammable,HFC-Free)Smoke Detector Tester
Approved all over the world, our Solo smoke aerosols (used with the Solo 330/332 dispensers) deliver smoke particles to the detector under test...
£22.70 Ex VAT
Add to Cart
SOLOA10-250
No Climb
(image for) Solo A10 250ml (Non-flammable,HFC-Free)Smoke Detector Tester
£21.25 Ex VAT
Add to Cart
SOLOA5-001
No Climb
(image for) Solo A5 (Flammable) Smoke Detector Tester - UL & ULC Listed
£20.95 Ex VAT
Add to Cart
