NVT
Displaying 1 to 12 (of 12 Products)
NV-226J-PV
NVT
(image for) NV-226J-PV UTP Video Passive Transmitter +12VDC Converter
The NV-226J-PV Video Transmitter +12VDC Converter is a passive (non-amplified) video transmitter combined with a 24VAC-to-12VDC converter. Designed...
£72.44 Ex VAT
Add to Cart
NV-216A-PV
NVT
(image for) NVT Model NV-216A-PV Video Transceiver
The NVT Model NV-216A-PV Video Transceiver with Power is a passive (non-amplified) device that allows the transmission of real-time monochrome or...
£39.32 Ex VAT
Add to Cart
NV-704J-PVD
NVT
(image for) NVT Model NV-704J-PVD Cable Integrator
Typically installed in the Wiring Closet or IDF room, the NV
£78.99 Ex VAT
Add to Cart
NV-218A-PVD
NVT
(image for) NVT NV-218A-PVD Power Video & Data Transceiver
The NVT Model NV-218A-PVD Video Transceiver with Power and Data is a passive (non-amplified) device that allows the transmission of real-time...
£92.66 Ex VAT
Add to Cart
NV-413A
NVT
(image for) NVT NV-413A 4 Channel Passive Tansciever
The NVT Model NV-413A Video Transceivers are passive (non-amplified) device that allows the transmission of real-time monochrome or color video over...
£221.00 Ex VAT
Add to Cart
NV-217J-M
NVT
(image for) NVT Single Channel Passive Video Transceiver
NV-217J-M Single Channel Passive Video Transceiver is a passive (non-amplified) device that allows the transmission of real-time monochrome or color...
£31.23 Ex VAT
Add to Cart
NV-208A-M
NVT
(image for) NVT NV-208A-M Video Transceiver Balun
OBSOLETE - No longer available   The NVT Model NV-208A-M Video Transceiver is a passive (non-amplified) device that allows the transmission of...
£36.87 Ex VAT
... more info
NVT-213A
NVT
(image for) NVT NV-213A Single Channel Video Passive Transceiver
OBSOLETE - Alternative CLICK HERE   The NVT Model NV-213A Video Transceiver is a passive (non-amplified) device that allows the transmission...
£81.22 Ex VAT
... more info
NV-214A-M
NVT
(image for) NVT NV-214A-M Video Transceiver
OBSOLETE- Alternative CLICK HERE   The NVT Model NV-214A-M Video Transceiver is a passive (non-amplified) device that allows the transmission...
£31.49 Ex VAT
... more info
NV-452R
NVT
(image for) NVT NV-452R 1.6Km 4 way Active Reciever
OBSOLETE - No longer available   The NVT Model NV-452R Video Receiver is an active (amplified) device that allows the reception of real-time...
£543.66 Ex VAT
... more info
NV-652R
NVT
(image for) NVT NV-652R 1.6Km Active Receiver
OBSOLETE - No longer available   The NVT Model NV-652R Video Receiver is an active (amplified) device that allows the reception of real-time...
£147.32 Ex VAT
... more info
NV-653T
NVT
(image for) NVT NV-653T 1.6Km Active Transmitter
OBSOLETE - No longer available   The NVT Model NV-653T Video Transmitter is an active (amplified) device that allows the transmission of...
£156.55 Ex VAT
... more info
