GJD Opal XL 35m External PIR
This popular & versatile motion detector works in conjunction with GJD's security lighting controllers, turning on the lights if movement is detected at a range of up to 35m.
The Opal external PIR detector is IP55 rated with a 10 to 35 metre detection range. It is an inconspicuous and extremely popular external PIR that works in conjunction with GJD’s security lighting controllers.
  • Works with GJD security lighting controllers
  • UV stabilised lens cover
  • Adjustable pan and tilt
  • High impact ABS housing
  • Pet immunity option
  • Internal fully adjustable bracket
Area 10 to 35m (adjustable) up to 750 sq m
Coverage 90º 35m x 30m max
Adjustment 180º pan + 90º tilt Area reduction mask (if required)
Lens Fresnel: 36 zone - White light filter
No. 1 Output ‘A’ Open collector -ve switching - 25mA max. Alarm period 400ms
No. 2 Output ‘S’ Open collector -ve switching - 25mA max Alarm period : detection +60 seconds Adjustable: Dusk (2 Lux) to 24 hour
Power Input 9 to 15VDC
Current 6mA (12V nominal)
Control Digital ASIC/microprocessor
Operating Temp -20º to +55º C
Protection Rating IP55 - High Impact ABS Housing
Dimension 104 x 104 x 94mm Weight 136 grams
Mounting Height - Variable - optimum height 3 metres
Cable up to 200m: standard 4 core 7/0.2mm up to 500m: 8 core 16/0.2mm use double core
  • Model: GJD020
  • Manufactured by: GJD
£47.94 Ex VAT
