Optex external synchronised twin beam 20m
The AX-70TN is a 20m indoor and outdoor hardwired active infrared (AIR) beam set, designed to protect driveways, loading bays in warehouses, open areas and small perimeters. The dual beam set can also be connected to an IP network when used in conjunction with the IP/POE module PIE-1.
Ideal for warehouse applications
The shortest and most compact of our active infrared beams, the AX-70TN is very popular for warehouse and distribution centres to detect if a loading bay is being used or empty and activate the shutter accordingly.
Weather resistant
IP65 rated, the AX-70TN housing has been designed to resist against both water and dust. The hood featured on the front cover is to prevent frost from attaching to the cover and potentially affecting the signal power. The beam is also fitted with specific relay and absorber to protect it from lightening surges.
Applications
  • Buildings
  • Garden
  • Driveway
  • Hardwired dual beam set
  • 99% beam blocking stability
  • IP65 structure with high sealing rubber packing
  • High grade spherical lens
Detection method Infrared beam interruption detection
Maximum detection range 20m (70ft.)
Maximum arrival range 200m (700ft.)
Interruption period Selectable between 50, 100, 250, and 500m sec.
Power supply 10.5 - 28V DC
Current consumption (transmitter + receiver) 38mA (max.)
Alarm period 2sec. (±1) nominal
Alarm output N.C. 28V DC, 0.2A (max.)
Tamper switch Opens when cover is removed at 28V DC, 0.2A max
Operating temperature -35°C to +60°C (-31°F to +140°F) Use the optional heating unit (HU-3) in conditions of -25°C (-13°F) or below
Operating humidity 95% max
Alignment angle ± 90° Horizontal, ± 5° Vertica
Mounting Wall and pole mounting
Weight (transmitter + receiver) 650g (22.9oz.)
Housing protection (EN 00529) IP65
  • Model: AX-70TN
  • Manufactured by: Optex
£72.00 Ex VAT
