Pyronix 2 Way Wireless Magnetic Contact and Shock Sensor Brown
Obsolete, only available while stocks last
Click here for alternative
Pyronix, MC1/SHOCKBR-WE, (BROWN) Full Two Way Wireless Shock Sensor with SSI Technology
We are delighted to announce the launch of the new MC1/SHOCK-WE combined shock and magnetic contact to join the Enforcer range of two-way wireless accessories. The product is specifically designed to be placed in positions where it is necessary for a shock sensor and magnetic contact to be present, such as on doors and windows; two sensors in one!
The sensors can both be learned separately to the panel allowing separate shock and magnetic contact transmissions of alarm signals to be sent to the panel. They can also be learned individually, if for some instance either the shock or the magnetic contact is not required.
The new MC1/SHOCK-WE will replace the current shock detector, SHOCK-WE, giving you increased battery life, along with greater flexibility of installation, an ethos which is carried right through the Enforcer two-way wireless range of products.
Signal Strength Indicator (SSI): One of the key advantages of implementing of the SSI technology is to allow the installer to view the wireless transmission signal strength on both the control panel and wireless devices in real time.
Features:
    Adjustable Sensitivity Settings
    Also available in Brown
    Front & Rear Tamper
    Signal Strength Indicator on the Device
    One Push To Learn Button
    868MHz Transceiver FM technology
    Pyronix High Security Wireless Protocol Encryption
Specification:
    Battery life: Greater than 2 years
    Operating Temperature: -10
    Battery Type: CR2 3.0 Volt
    Transmission Frequency: 868MHz FM Transceiver Narrow Band
    Transmission Method: Fully Encrypted Rolling Code
    Transmission Range: 300m Free Space
  • Model: MC1/SHOCKBR-WE
  • Manufactured by: Pyronix
£54.90 Ex VAT
