Ultimate flexibility
The Enforcer V11 offers a comprehensive security solution for any property, thanks to its wide range of wired and wireless security and life safety peripherals.
HomeControl2.0 control
Users can securely control the system, check its status, and receive customised push notifications from any location via our easy-to-use HomeControl2.0 smart device application.
Streamlined connectivity
These devices offer smooth connectivity through a user-friendly one-button learning feature, facilitate optimal device placement during installation via SSI, and incorporate ITDC for effective power management.
Programming options
Offering programming options via the InSite desktop application or keypad, the Enforcer V11 allows engineers to choose their preferred method for seamless menu navigation.
IP Ready
The Enforcer V11 effectively addresses the challenges caused by the PSTN shut off, with Wi-Fi onboard and GPRS or LAN alternative options, users won’t encounter PSTN-related issues.
Easy IT configuration
The Enforcer V11 connects via a cloud server, avoiding the need for difficult on-site IP or network setup. Users connect through PyronixCloud.com for hassle-free access.
InSite compatible
With our InSite UDL software, the system can undergo remote programming and diagnostics. Additionally, this software facilitates the remote execution of one of the compulsory bi-annual system maintenance checks.
HD monitoring on HomeControlHUB
View up to 16 cameras on the HomeControlHUB app for live monitoring of the property. Connect existing cameras through logging in using a ProControl+ or Hik-Connect account.
SIA DC09 compatibility
In accordance with the latest Digital Communications Standard, our newest update features SIA DC09 compatibility.
Including SIA DC09 compatibility in our update allows for direct ARC communication, without the need for any additional hardware and software. It will mean the management of ARC communications are all in one place and will make maintenance and support much easier too.
Interlinking Smoke and Heat sensors
This new feature enables our Smoke and Heat sensors to interlink, meaning all detectors in a property will sound at once with activation.*
*Smoke and Heat sensors with the latest software (version V4.00) are required.
What’s in the box
The Enforcer V11 is supplied with Wi-Fi onboard and a User Guide.
Two-way wireless technology | Yes |
Independent areas | 4 |
Part sets | 4 |
Tamper protection | Front and rear |
LCD keypad with integrated proxmity reader | Yes |
User codes and prox tags | 80 |
Guard codes | 10 |
Reporting formats | WIFI / DIGI-LAN: Contact ID IP, Fast Format IP, SIA IP, Push Notifications. | DIGI-GPRS / DIGI-GPRS+SIM: Contact ID IP, SIA IP, Push Notifications and SMS (SMS not with DIGI-GPRS+SIM). | DIGI-1200 / DIGI-GSM: Contact ID, Fast Format, SIA and SMS. |
System logs | 750 |
Enforcer two-way wireless technology
Signal Strength Indicators (SSI) | Yes |
Instant two way device control (ITDC) | Yes |
Pyronix high security two way wireless data encryption protocol (TDE) | Yes |
Pyronix intelligent jamming detection | Yes |
Programmable wireless supervision time | Yes |
868MHz transceiver FM technology | Yes |
One push to learn | Yes |
Transmission method | Fully encrypted rolling code | (4294967295 combinations) |
Transmission range | 300m in open space |
Inputs & outputs
Zone type | Wireless and Wired |
Channels | 2 |
Two-way wireless zones | 64 (maximum with additional wireless expander) |
Onboard wired zones | 2 (wired to I/O board) |
Wired EOL zones | 34 (maximum with additional wired expanders) |
Wired double pole zones | 32 (must use EOL mode 4k7/2k2 and wired expanders) |
Total zones | 66 |
Outputs on board | 3 (PGM1, STB, BELL) |
Two-way wireless keypads | 4 |
Output modules | 1 |
Maximum outputs | 38 |
Two-way wireless keyfobs | 32 |
Two-way wireless sirens | 2 |
Wired keypads | 4 (Including the Enforcer control panel) |
Readers and entry control | 3 |
Input expansion layout
Onboard | 1 - 34 |
ZEM 0 | 35 - 42 |
ZEM 1 | 43 - 50 |
ZEM 2 | 51 - 58 |
ZEM 3 | 59 - 66 |
Communications and modems
Modem type (included) | Wi-Fi onboard |
GPRS modem (optional) | Yes |
LAN modem (optional) | Yes |
PSTN modem (optional) | Yes |
Supports PyronixCloud & App | Yes |
SMS numbers | 10 |
Event signalling to Insite | Yes |
Formats | Contact ID, Contact ID IP, Fast Format, Fast Format IP, SIA, SIA IP, Push notifications and SMS |
SIA | Yes |
Contact ID | Yes |
ARC compatibility | Yes |
Compatible with UDL software | Yes |
Voice modem / PSTN speech dialler (optional) | Yes |
Environmental and operating features
Storage temperature | -20C to +60C |
Certified operating temperature | -10C to +40C |
Nominal operating temperature | -10C to +50C |
Alarm period | 15 mins maximum |
Physical dimensions (W x H x D) | 220 x 160 x 50mm |
Weight | 1025g |
Electrical & battery
Battery type | NiMH 8 cell 2200mAh rechargeable battery |
Battery life | 3 - 5 Years |
Battery capacity | 2200mAh |
Battery voltage | 11V (with no mains and battery fully charged) |
Certifications and warranty
Security Grade | Grade 2 |
Environmental class | II |
EN Certificate | EN 62368-1:2014 + A11:2017 | EN 50131-1: 2006 + A1: 2009 +A2:2017 | EN 50131-3: 2009 | EN 50131-6: 2017 | EN 50131-5-3: 2017 | EN 50130-5: 2011 | EN 50130-4: 2011 + A1: 2014 | PD 6662: 2017 |
Certificate number | CA12.01328 |
Electrical conformity | CE |
Warranty | 2 years |
