Pyronix Enforcer 32 Zone ENF32GB-WE Panel
Product Features
- Enforcer two-way wireless technology
- 868MHz Transceiver FM technology
- Instant two-way device control (ITDC)
- Signal Strength Indicator (SSI)
- 4 Level sets
- 32 Wireless inputs
- 2 Wired inputs & 3 Wired outputs on board
- 80 User codes
- 32 Wireless keyfobs with individual user ID
- In built proximity reader
Panel Type: Domestic & Commercial
Get superior protection with Enforcer two-way wireless technology
Enforcer two-way wireless technology gives you a highly secure, fexible security system.
The two-way wireless keyfob allows you to set/unset the system (with visual indication of alarm, faults and system status), and to control wired automation outputs.
Advanced jamming detection with frequency hopping technology is used to prevent accidental or malicious attempts to disrupt the system.
128 bit wireless protocol encryption ensures effective anti-code grabbing and multiple attempts at message delivery. This gives a very high level of protection over the wireless bus, ensuring you have peace of mind that your system is safe and secure.
One-push-to-learn
The one-push-to-learn feature in all Enforcer wireless devices means that learning devices onto the system can be done in seconds.
Pyronix High Security Wireless Protocol Encryption
The two-way wireless protocol has been developed by Pyronix to ensure that the communications between all wireless system components are protected with a very high security level. The protocol uses the 128 bit Pyronix advanced encryption.
Quicker installation with Signal Strength Indicators
Signal Strength Indicators (SSI) in all wireless devices means that you can position devices without the need to refer back to the panel.
Preserve battery power
Instant two-way device control enables immediate wake-up and sleep of devices; preserving battery power, while maintaining a highly secure system.
Easy to program and install
Fully menu driven programming with YES/NO questions allows for quick and simple installing; saving you time and money.
No wires, no fuss
As the system can be fully wireless, there is no need to run wiring; saving you time, money and mess.
A full range of peripherals
Including safety and security sensors and detectors, the Enforcer range has the products to cover the job.
Control panel technical characteristics
Two-way wireless technology Yes
Part sets 4
Tamper protection Yes
User codes and prox tags 80
Reporting formats Digi GSM: SMS, Fast Format, CID
or Digi PSTN: SMS, Fast Format, CID, SIA 3, ARM®
System logs 750
Signal Strength Indicators (SSI) Yes
Instant two way device control (ITDC) Yes
Pyronix high security two way wireless data encryption protocol (TDE) Yes
Pyronix intelligent jamming detection Yes
Programmable wireless supervision time Yes
868MHz transceiver FM technology Yes
Transmission method Fully encrypted rolling code
Transmission range 300m in open space
Inputs & outputs
Input type Wireless and wired
Two-way wireless inputs 32
Onboard wired inputs 2
Total inputs 66
Outputs on board 2
Output modules 1
Maximum outputs 38
Two-way wireless keyfobs 32
Two-way wireless sirens 2
Wired keypads 3
Readers and entry control 3
Communications and modems
Modem type (included)
PSTN (GSM modem available in ENF GSM KIT 1)
GSM modem (optional)
Yes
PSTN modem (optional)
Yes
Environmental and operating features
Storage temperature
-20°C to +60°C
Certified operating temperature
-10°C to +40°C
Nominal operating temperature
-10°C to +40°C
Physical dimensions (H x W x D)
220 x 160 x 50mm
Weight
1025g
Electrical & battery
Battery type
NiMH 8 cell 2200mAh rechargeable battery
Battery voltage
12.71V (with no mains and battery fully charged)
Low battery threshold
8.9V
Mains supply
230V AC -15/+10%
Operating voltage
90 - 264V AC
Supply current
222 - 75 mA
Resistance (wired inputs)
Normal
3k7 or 8k3
Intruder
8k4 to 10k2
Tamper
<3k7 or >23k
Certifications and warranty
Electrical conformity
CE
EN Certificate
EN50131-1:2006+A1:2009
EN50131-3:2009
EN50131-6:2008
EN50131-5-3:2005+A1:2008
PD6662:2010
Certification type
Self-certified
Environmental class
II
Warranty
2 years
Security Grade
Grade 2
