Pyronix Enforcer Kit 2
Keeping you ahead of the curve with DIGI WIFI included as standard
PSTN and traditional phone lines continue to develop issues since the move to digital, while IP communications and push notifications with smart apps go from strength to strength. So, a DIGI-WIFI module* is supplied for free, as standard, with the Enforcer V11 to deliver PyronixCloud and HomeControl+ connectivity and all the benefits they provide.*
Safe on the go control & monitoring with the HomeControl+ App & PyronixCloud
  • Complete control from anywhere in the world
    Set and unset the system, get system status and receive custom push notifications from any event.
  • HD monitoring
    Add IP cameras to the system for live stream monitoring of the property.
  • Android & Apple compatible
    The HomeControl+ App is available in two versions: on Android™ from the Google Play Store, and on iOS™ from the Apple App store.
  • Highly secure connection
    The HomeControl+ App and PyronixCloud communications are encrypted to the highest standard.
  • No on-site IT configuration
    The Enforcer V10 and EURO 46 APP are connected through a cloud sever, so there is no need to set up static IP addresses or configure the network connection on site, instead you simply set up an account on PyronixCloud.com.
  • Recurring revenue & retention
    Streams of recurring revenue can be established by offering PyronixCloud management services; managing this or passing access to users. This increases customer retention and makes the system more profitable.
Connect as required with the complete compatibility with all communication options
Whatever the communication need, the Enforcer V11 gives you the option. Simply purchase the option you want and fit it into the panel. Loud & obvious alarms with local sounder & LEDs.
Get to know one & master them all, with fully menu-driven programming
Easily navigate through the menus of the Enforcer V11 or EURO control panels with the same uniformed menu-driven programming. Simple ‘YES/NO’ questions allow fast and efficient installing to save both time and money.
Kit Contents
*Please note within the kit the cover and backplate are not included - over colours are available
  • Model: ENF/KIT2-UK
  • Manufactured by: Pyronix
£234.60 Ex VAT
