Risco ShockTec Plus With Contact Grade 3
RISCO (RK601SMG3), ShockTec Plus Grade 3
ShockTec Digital Shock Detector
RISCO’s ShockTec Plus Digital Shock Detector offers reliable 24-hour perimeter protection, ensuring that a break-in is detected as soon as an intruder attempts to force, smash, drill or even saw through a protected window, door, wall or roof.
An advanced digital microprocessor analyses the vibration signal received from the electric sensor and ShockTec Plus incorporates a unique feature – digital sampling of the signal simultaneously in two separate channels which enables precise measurement and analysis of the shock signal. The ShockTec Plus model also has a door/window magnetic contact and a magnetic reed switch for double protection.
Digital microprocessor with intelligent digital signal processing
Encapsulated bi-morph piezo electronic sensor
Tri-colour LED enables customized calibration
Gross attack detection
Magnetic contact option
Unique features
Digital analysis of vibration signals from the electronic sensor enables precise measurement and reliable analysis of the shock signal and consequent threat potential
False alarm reduction
Intelligent digital signal processing prevents false alarms owing to naturally caused vibrations
Tamper proof
Incorporates technology that prevents tampering through the use of large magnets
  • Supply voltage 9V-16V DC
  • Current consumption 7.5mA (typical)
  • Operational temperature -20°C to 60°C
  • Maximum humidity 95% non-condensing
  • Sensitivity setting Dual stage potentiometer
  • Tri-colour LED indicator Orange-over-sensitive, green: alarm & correct calibration, red: under-sensitive
  • Contact ratings
    • Alarm relay 100mA at 24VDC, NC, Optorelay
    • Tamper relay 500mA at 24VDC, NC
    • Reed relay 100mA at 24 VDC, NC
  • Alarm time 2.5 seconds
  • Latching modes Any or first to latch operation modes
  • Max mo. of units on any latch loop 80
  • Max no of units on 1st to latch loop 10
  • False alarm protection Digital microprocessor signal processing and noise reduction with maximum ground plane
  • Electrostatic discharge No false alarms up to 8kV
  • RF immunity 40 V/m from 80MHz to 1GHz
  • Enclosure material Flame retardant ABS
  • Enclosure dimensions 25 x 28 x 95mm for detector, 10 x 12 x 58mm for magnet
  • Model: RK601SMG3
  • Manufactured by: Risco
£14.01 Ex VAT
