Rokonet
Displaying 1 to 9 (of 9 Products)
RK412PT
Rokonet
Rokonet
Risco Digisense ZoDiac Pet PIR 12m
RISCO (RK412PT) Digi-Sense 12m pet immune PIR detector G2 The DigiSense digital detector series is the ideal choice for both commercial and...
£18.04 Ex VAT
Add to CartRK150DTIG3
Rokonet
Rokonet
Rokonet DT 360 Ceiling Mount Grade 3
The Risco LuNAR DT detector dramatically reduces false alarms via its combination of dual-element passive infrared technology with microwave,...
£42.00 Ex VAT
Add to CartRK312PR
Rokonet
Rokonet
Rokonet WatchOUT PIR + Swivel Bracket 12m
OBSOLETE - No longer available WatchOUT PIR incorporates the Digital Correlation Technology that uses 2 PIR channels with interlacing...
£72.24 Ex VAT
... more infoRK508
Rokonet
Rokonet
Rokonet Meteor Curtain PIR 12m
OBSOLETE - No longer available Easy to Install PIR Detector for Curtain Applications (RK508) The MeTEOR passive infrared detector, with its...
£10.12 Ex VAT
... more infoRK410PR
Rokonet
Rokonet
OBSOLETE - Alternative Click Here The ZoDIAC PRO detector provides full 12m x 12m (40ft x 40ft) coverage with excellent false alarm...
£7.98 Ex VAT
... more infoRK600S
Rokonet
Rokonet
Risco Rokonet ShockTec Shock Detector White
OBSOLETE - Alternative Click Here The ShockTec detectors have a reliable built-in calibration method that prevents over or under sensitive...
£9.98 Ex VAT
... more infoRG61G
Rokonet
Rokonet
Risco Vitron Grade 2 Glass Break Detector
OBSOLETE - No longer available ViTRON detectors employ a Microprocessor-based sound analysis with continuous automatic testing to enhance...
£19.35 Ex VAT
... more infoRK601SM
Rokonet
Rokonet
Rokonet ShockTec with Magnet White
OBSOLETE - Alternative Click Here The ShockTec with Magnetic Contact ensure double protection on opening windows and doors. The detector can...
£12.23 Ex VAT
... more infoRK325DT
Rokonet
Rokonet
OBSOLETE - No longer available WatchIN Grade 3 DTAM c/w Standard Swivel and Barrier replacement lens [RK325DT] Provides superior catch...
£75.03 Ex VAT
... more infoDisplaying 1 to 9 (of 9 Products)
