Eaton Wireless Keyfob 4 Button
Key-fobs for intruder alarm systems The PD6662:2017 compliant two-way key-fob (FOB-2W-4B) and one-way key-fob (i-FB01) both enable the user to remotely unset/set the system.
The two-way keyfob provides feedback on system status and confirms that the system has been set upon exit whilst the two-way keyfob can be programmed to be used as a panic button.
Both are designed to fit comfortably in your pocket or on a key ring.
Compatible with all current Eaton security control panels.
At a glance...
  • Long-life lithium battery
  • Two-way key-fob provides system status
  • Replaceable battery
  • Enhanced transmission range (FOB-2W-4B)
  • Configurable set/unset
  • Learnt to user profile not radio zones so doesn’t reduce the detection capability of the system
  • Programmable output button which can be used to operate motorised gates etc.
Product CodeFOB-2W-4B
Radio frequency868.6625 MHz
Transmission range (m)200 m
EN 50131 grade2
Environmental classClass II
Operating temperature (°C)-10 to 55
ColourBlack
Battery quantity1 x CR2450
Dimensions58 x 38 x 19mm HxWxD without keyring shackle Keyring plus shackle adds 26mm to length
All i-on panels with software version 4.0 or above
Menvier40, Menvier100, Menvier300
Eaton Was Scantronic
  • Model: FOB-2W-4B
£49.71 Ex VAT
