Only avaliable while stocks last
Fully compatible with the next generation of Scantronic i-on control panels, Eaton’s CAM-INT-00 internal IP camera provides peace of mind to the user by verifying alarm events with full HD 1080P quality
User can be emailed images of events as they happen, for example: - confirm the presence of an intruder in the property - following a system unset, receive verification that the kids are home from school - identify the source of a fire when the DET-RSMOKE is activated.
At a glance...
- High definition 1080P camera
- Built-in web server for straightforward configuration
- Wi-Fi or wired Ethernet connectivity
- Power over Ethernet or local Power Supply Unit
- Night IR up to 8 meters
- 15 images provided: 5 images pre and 10 images post event
- Firmware upgradeable
- Compatible with the next generation of i-on (Software version 5 and higher)
- WPS Enabled
Product specification
Product Code | CAM-INT-00 |
RAM | 256 MB |
Flash | 16 MB |
Image sensor | 1 / 2.9” Mega-Pixel CMOS Sensor |
Operating temperature | 0°C ~ 45°C |
Sensitivity | Colour: 0.1 Lux (ACG ON) B/W: 0.05 Lux (AGC ON) |
Lens type | 3.6mm @ F2.0 |
View angle | 78°(H), 42°(V) |
Power consumption | DC 12V Max: 2.38W |
Wi-Fi | 802.11b/g/n |
LEDs | 4 LEDs, 850nM |
IR Distance | 8 Meters |
Video adjust | Brightness, Contrast, Hue, Saturation, Sharpness, AGC, Shutter Time, Sense-Up, D-WDR, Anti Fog, Lens Distortion Correction, Flip, Mirror, Day&Night Adjustable, Red Gain and Blue Gain, Denoise |
Dimensions | 100 mm x 62 mm x 44 mm (excluding stand) |
Eaton Was Scantronic
