Scantronic I-ON 40 40 zone hybrid alarm control panel & Wired KP
Please see the [I-on40H]
Keypad included
i-on40 is a 40 zone control unit for hybrid wired/wirefree alarm systems intended for domestic and light commercial use.
The control unit comprises an end station with remote keypads. The simple-to-install end station has an ABS plastic case which contains the radio transceiver, power supply and backup battery. Up to four keypads connect to the end station by standard alarm cable, allowing the end user to set and unset the system, and the installer to fully configure the control unit. The keypads also contain integral proximity tag readers, so that end users can control the system without having to remember access codes.
The control unit works with Cooper Security Ltd's 700 series 868MHz narrowband wireless peripherals. These include:
  • Door contact/universal transmitter
  • Passive infra red detector
  • Smoke detector
  • External siren
  • Four button remote control
  • Remote radio keypad
During programming the installer can set up the system as either a part setting system with full set and three part sets, or a partitioned system where each of the four partitions has full set and a single part set.
The i-on40 offers a wide range of communication options. Plug-on modules provide connection to either the telephone system (PSTN), the mobile phone network (GSM) or the internet via Ethernet or GPRS. In addition, the control unit provides a set of output pins which can be used to drive stand-alone communicators.
To make the installation and maintenance simple, the control unit also provides an Ethernet connector for attaching PCs or laptops. The control unit can be programmed using a standard web browser from an Ethernet connected laptop..
Specifications
General
Product name
i-on40.
Product Description
40 zone hybrid endstation with remote keypads.
Manufacturer
Cooper Security Ltd.
Environmental
Class II.
Operating temperature
Tested -10 to +55°C.
Humidity
0 to 75% RH, non-condensing.
Dimensions:
End station
384 x 245 x 94, mm HxWxD.
Keypad
115 x 156 x 34, mm HxWxD
Weight:
End station
2.2 kg (without stand-by battery).
Capacities
Zones
24 radio, 16 wired.
Outputs
16 wired (comprising two voltage free contacts, 14 transistorised of which 12 are provided on two separate wiring harnesses).
8 radio (with suitable products such as the 770r Wireless Accessory Module).
Internal Clock
±10 minutes over one year (depending on the accuracy of the mains supply frequency).
Remote controls
50.
Panic Alarms
50.
External Radio Sirens
4
Log capacity
Up to 1,000 events, stored in flash memory (requires no support battery)
Security
Security Grade
Grade 2.
Radio detector differs
16,777,214 (2^24-2).
Radio Supervision
Programmable.
Access code
4 digits, all four digits may be any number 0 to 9, giving 10,000 differs.
Number of access codes
50 plus installer
Code blocking
Blocked for 90s after four incorrect codes in series.
Proximity tag differs
4,294,967,296 (2^32)
Radio
Radio Section
Operating frequency 868.6625MHz Narrowband.
EN 300 220-3.
EN 300 330-2
Transmitter range
The range of the transmitters compatible with this control unit depends on the environment in which they are installed. As a guideline, most transmitters will work up 200m range in free space conditions.
Power Supply
This product complies with the requirements of EN50131-6 Type A power supply at security grade 2 and environmental class II.
Mains power supply
230VAC +10%/-15%, 170mA max, 50Hz.
End station psu
13.7VDC, 1.5A max
End station consumption
130mA min.
220mA max.
Communicator consumption
50mA max
Keypad consumption
30mA (backlight off)
45mA (backlight on)
65mA (backlight on max)
Standby Battery
12V, 7Ah sealed lead acid.
Standby time:
More than 12 hours depending on ancillaries connected to control unit.
Max recharge time:
 less than 72 hours.
Battery charge limit
270mA
12V Aux supply (inc LS)
13.7VDC +0.1/-0.4 @ 850mA max.
14V4 supply
14.4V +0.1/-0.2 @ 230mA
12V Keypad bus
13.7V =0.1/-0.5 @ 400mA max
Monitoring includes
Mains fail, battery low voltage, battery failure.
Electromagnetic Compatibility
Immunity
Conforms to EN50130-4.
Emissions
Conforms to EN61000-6-3.
Outputs
O/P 1 - 2
Voltage free, single pole relay contacts rated 24VDC @ 1A or 120VAC @ 0.5A.
O/P 3 - 4
Open collector transistor, +12VDC when inactive, 0V when active. 500mA max.
O/P 5 - 16
LS (loudspeaker)
Min impedance 16 Ohm, current consumption from 12VAux = 280mA in alarm.
Fuses
The control unit has a T250mA mains fuse.
  • Model: I-ON40-KEYKP01
  • Manufactured by: Scantronic
£183.27 Ex VAT
