Scantronic i-on30EXD contains a built-in ATS2 communicator & RKP
Alternative Click Here
The proven expandable i-on platform now includes a 30 zone version.
The i-on30EX can be installed to EN50131-1 grade 2 up to 30 zones over 4 partitions and can accommodate 50 users each of which can use a PIN, prox, remote control and PA button to operate the system making it support an incredibly versatile system.
The system offers a unique range of benefits to installers:
Flexibility
Choose a panel with or without digi for a cost effective, fully hybrid solution
Performance bus - fit up to 10 bus devices; expanders, keypads or power supplies
Easy to install
Semi-Auto Addressing - Prevents address duplication for bus mounted devices, saving hours of installation diagnostic time
Decimal Expansion - expanders have 10 zones (30 radio zone option available) in addition to the 10 zones on the end station. Zone identification on expanders is now considerably easier
Easy to service
Audible Bus Device Tracing - locate any bus device quickly and easily; reducing the time taken to complete maintenance and service calls
Reliable to use
Built on the i-on platform with thousands of panels installed
i-on architecture proven in the market with a much larger zone and bus device capacity
Keypad included KEY-KP01
The i-on30EX is a control unit for a hybrid wired/wirefree alarm system intended for commercial or large domestic use.
The control unit comprises a steel case containing the control unit pcb (printed circuit board), power supply and space for a 7Ah backup battery.
The control unit pcb provides terminals for a single bus. The bus allows you to connect up to 10 peripheral devices using standard four wire alarm cable. The peripheral devices can be any mixture of keypads, zone expanders (for wireless or wired detectors) or remote power supplies.
The control unit pcb also provides a range of connectors for outputs, communicators, and up to 10 FSL (Fully Supervised Loop) or five CC (Closed Circuit) zones.
The i-on30EX uses i-kp01 keypads with software revision 2.0 and above. The keypads allow end users to set and unset the system, and the installer to configure the control unit. The keypads also contain integral proximity tag readers, allowing end users to control the system without having to remember access codes.
A range of wireless peripherals is available for operation with the wireless expanders. The range includes a door contact/universal transmitter, a passive infra red detector, smoke detector, external siren, 4 button remote control, and remote radio keypad.
This control unit is designed and approved to be used as part of a Security Grade 2 system.
Communications
The i-on30EXD version of the control unit contains a built-in ATS2 communicator, allowing it to comply with EN50131 at Security Grade 2.
The i-on30EX also provides sockets for an add-on communication module.
Level Setting or Partitioned System
The i-on30EX offers two basic ways of behaving as an alarm system:
In Part Setting system the i-on30EX can set in one of four ways: either Full set or three varieties of Part Set.
In a Partitioned system the i-on30EX provides the equivalent of 4, smaller, independent alarm systems. Each system is a "Partition" of the i-on30EX. You can allocate any zone to each Partition. Each zone can also belong to more than one Partition. Each Partition can have a Full Set level and one Part Set level. During installation the installer can allocate keypads, sounders or outputs to any of the partitions.
Installer Programming Interface
As an installer you can program the control unit through any compatible keypad connected to the bus cable. The Installer Menu allows you to specify all the operating parameters for an individual installation.
If you wish, you can also connect a PC or laptop to the USB port on the control unit pcb and use Cooper Security's Downloader software to program the control unit.
  • Model: I-ON30EXDKP
  • Manufactured by: Scantronic
£114.31 Ex VAT
