Eaton Optical Wireless Smoke Detector
The DET-RSMOKE is an optical radio smoke detector designed to work with Eaton’s   range of radio and hybrid control panels.
Providing a flexible solution to smoke detection, it has its own built-in sounder for local alarms and can be programmed to trigger control panel sounders.
Using Eaton’s proven leading radio technology the device is compatible with i-on, and all legacy 868 systems. Installers can utilise the full range of communications options across the panel ranges.
The DET-RSMOKE is ideal for use in a range of premises but it is not designed to substitute EN54 Systems
At a glance...
  • Independently certified to EN14604
  • Uses AA alkaline batteries
  • Twist and lock installation for easy fitting and removal
Product codeDET-RSMOKE
ConnectionRadio
Operating humidityup to 95%
Operating temperature-10°C to +65°C
MaterialPlastic
Battery type3 x AA Alkaline
Battery service life24 months
Environmental classII (tested to -10°c + 65°c)
Operating Frequency868.6625 MHz
Tamper protectionYes
ComplianceIndependently certified to EN14604
Dimensions122mm (diameter) x 50mm (h)
Eaton Was Scantronic
  • Model: DET-RSMOKE
£71.31 Ex VAT
