Eaton Wireless Sounder External Blue Backplate Only
A range of external sounders, in three colours, with options for radio, wired and decoy. The decoy sounder includes working LEDs identical to the genuine wireless sounder to act as a deterrent. Designed for use with i-on control panels new and legacy 868MHz systems. Wired variants also compatible with third-party control units
Engineer-friendly: a self-supporting lid, built-in spirit-level and revolving fixing holes for ease of installation including on uneven surfaces
High-power comfort LEDs and LED strobes: provides reassurance for the user
Common enclosure for entire range: impact-resistant polycarbonate construction in a choice of 3 colours: blue, amber and red
At a glance...
  • Wired sounder selectable between Self Contained Bell (SCB) or Self Actuated Bell (SAB) modes:
    • In SCB mode the sounder, in alarm condition, draws its power from its integral internal battery
    • In SAB mode the sounder is driven from the control panel
  • Low-volume maintenance mode
    • Self-supporting lid
    • Built-in spirit level
  • Sound output 100 dB at 1 meter
  • Low current consumption (35mA and 225mA in-alarm current)
  • Front and rear tamper (except SDR-DEXT)
  • Lid and rear tamper detection
  • Selectable cut-off timer
  • Choice of siren tones
  • Compliance: EN50131-4 Grade: Grade 2 (SDR-WEXT-G2 and SDR-REXT-G2), or Grade 3 (SDR-WEXT-G3),PD6662:2017
Product codeSDR-REXT-G2
Sound Output100 dB(A) at 1m
Weight1.4kg
Operating temperature-25°C to +60°C
Max Relative Humidity95%
IP ratingIP65
Cut off timerSelectable: 5 secs, 3 mins, 15 mins
Wireless frequency868.6625 MHz
Battery packs2 x 3V Alkaline
Dimensions290mm (h) x 277mm (w) x 80mm (d)
For the cover please order  [SDR-CV]
SDR-REXT-G2 SDR-WEXT-G2 SDR-DEXT SDR-WEXT-G3
Eaton Was Scantronic
  • Model: SDR-REXT-G2-BL-NC
£68.68 Ex VAT
