SecWare Eco 600TVL VR IR dome - Dark Grey
Description
Medium resolution day/night during the day & monochrome at night dome camera with a 2.8-12mm varifocal lens. The camera is mounted in a robust aluminium housing that offers a 3 axis gimbal allowing the camera to be moved in any direction. This allows the dome to be mounted on either the ceiling or a wall. The camera incorporates a dual glass technology that completely eliminates IR LED reflection in to the lens at night. The camera is fitted with IR LEDs that allow the camera to be used in total darkness up to a range of 30 metres. The camera is IP65 rated and can be fitted outdoors.
Specification
Image Sensor Sony CCD
Lens Mega Pixel lens 2.8-12mm lens
Resolution 600TVL
Video System NTSC/PAL
Video Output 1 BNC, 1.0 Vp-p, 75 Ohm Composite
Sync. System Internal
Min. Illumination Color: > 0.1 Lux
Electronic Shutter NTSC: 1/60 ~ 1/100,000, PAL: 1/50 ~ 1/100,000
OSD Control NO
White Balance ATW
IR 36pcs* 5 Led with 30M Distance
D-WDR Yes
BLC Auto
Gain Control Auto
Chasis Material & Color Metal housing
Supply Voltage DC12V
Power consumption 200mA/450mA(with IR ON)
Operating temperature -15˚C ~ 50˚C
Weight Approx.500g
  • Model: ECODOME2.8MM
  • Shipping Weight: 0.8 kgs
£63.49 Ex VAT
