Secware Pro 3.6mm MP Sony effio-E 700TVL Internal Dome White
Description
High resolution day/night during the day & monochrome at night dome camera with a 3.6mm fixed iris lens. The camera is mounted in a robust plastic housing. This allows the dome to be mounted on either the ceiling or a wall. The camera incorporates a dual glass technology that completely eliminates IR LED reflection in to the lens at night. The camera is fitted with IR LEDs that allow the camera to be used in total darkness up to a range of 20 metres.
Specification
camera Model: SI5221F-17-B        Plastic Dome Camera
Image Sensor 1/3"Sony ExView ICX673AK +Effio-E 4140  sensor
Lens 3.6mm fixed lens
Resolution 700TVL
Video System NTSC/PAL
Video Output 1 BNC, 1.0 Vp-p, 75 Ohm Composite
Sync. System Internal
Min. Illumination Color: > 0.1 Lux
Electronic Shutter NTSC: 1/60 ~ 1/100,000, PAL: 1/50 ~ 1/100,000
OSD Control no
White Balance ATW
IR 24pcs*  Led with 20M Distance
D-WDR Yes
BLC Auto
Gain Control Auto
Chasis Material & Color Plastic housing
Supply Voltage DC12V
Power consumption 200mA/350mA(with IR ON)
Operating temperature -10˚C ~ 50˚C
Weight Approx.300g
  • Model: SI5221F-17-B
  • Shipping Weight: 0.7 kgs
£45.00 Ex VAT
