Siemens ADMQ12+AO-PE-01 E-Line 12m Wide Angle Pet Immune PIR
Avaliable While Stocks Last
Please click here for alternative
The E-Line PIR detectors deliver the fastest installation time on the market thanks to their innovative End of Line concept. High precision Fresnel optics and progressive signal analysis are combined to deliver best-in class detection reliability and quality. Ideal for residential and commercial applications‚ they offer the highest false alarm immunity thanks to wide ranging functionality‚ including flexible sensitivity adjustments‚ white light and temperature compensation‚ and pet immunity for allround performance and installation versatility.
Technical data
Range
12 m preset (volumetric), widely adjustable
Optical system
Fresnel
Sensitivity adjustment
PIR: jumper, potentiometer
Pet immunity
12 / 30 kg adjustable
Walking speed
0.2 ~ 3 m/s
Supply voltage
9.6 ~ 16 VDC (typical)
Current consumption
18 mA
End of Line board provided
AO-PE01 EOL PCB 2-wire type 1
Alarm relay output (NO/NC)
30 VDC / 80 mA / Ri 32 Ohm NC
Tamper relay output (NO/NC)
30 VDC / 80 mA NC
Control input
Remote Walktest
(high ≥ 3,5 V = LED's on)
Housing protection
IP41
Operating temperature
-10 ~ +55 °C
Dimensions (W x H x D)
62 x 121 x 40 mm
Weight
0.090 kg
Standard / approval
EN50131-2-2 Grade 2
  • Model: ADM-Q12+AO-PE-01
  • Shipping Weight: 0.09 kgs
  • Manufactured by: Siemens/Vanderbilt
£9.93 Ex VAT
