Siemens E-Line, Dual, G2, Wide Angle Pet Immune
OBSOLETE - Alternative click here
Description
The E-Line PIR detectors deliver the fastest installation time on the market thanks to their innovative End of Line concept. High precision Fresnel optics and progressive signal analysis are combined to deliver best-in class detection reliability and quality. Ideal for residential and commercial applications‚ they offer the highest false alarm immunity thanks to wide ranging functionality‚ including flexible sensitivity adjustments‚ white light and temperature compensation‚ and pet immunity for all round performance and installation versatility.
Technical data
Range12 m preset (volumetric), widely adjustable
Optical systemFresnel
Microwave (MW)10.687 GHz
Sensitivity adjustmentPIR: DIP switch, potentiometer,
MW: DIP switch, potentiometer
Pet immunity12 / 30 kg adjustable
Walking speed0.2 ~ 3 m/s
Supply voltage9.6 ~ 16 VDC (typical)
Current consumption34 mA
End of Line board providedAO-PE01 EoL Board PCB 2-wire type 1
Alarm relay output (NO/NC)30 VDC / 80 mA / Ri 32 Ohm NC
Tamper relay output (NO/NC)30 VDC / 80 mA NC
Control inputRemote Walktest
(high ≥ 3,5 V = LED's on)
Operating temperature-10 ~ +55 °C
Housing protectionIP41
Dimensions (W x H x D)62 x 121 x 40 mm
Weight0.105 kg
Standard / approvalEN 50131-2-4 Grade 2
  • Model: ADM-QXC12EE-01
  • Manufactured by: Siemens/Vanderbilt
£21.82 Ex VAT
