Siemens MAGIC Dual Detector, 12m wide angle
Vanderbilt`s MAGIC PIR and Dual motion detectors are an exciting new advance in security that provide the most reliable, convenient and cost effective solution for industry leading catch performance and false alarm immunity. The detectors feature a modern, slim design and share the same low-profile housing so intruders cannot tell which type of detector they are faced with. MAGIC PIR and Dual detectors are offered in either 12m or 18m range and are optionally available with integrated anti-masking technology.
The PDM-IXx12 and PDM-IXx12T dual motion detectors offer reliable detection of intruders and high false alarm immunity. Their performance is based on an improved version of Vanderbilt`s Matchtec algorithm, which combines passive infrared (PIR) and microwave (MW) channels to make extraordinarily accurate decisions on motion within their detection zone.
Intelligent processing routines analyse the relative strength of the IR and MW signals received from a moving object in order to make sound decisions. It is even possible to use multiple detectors in close proximity to each other, since the algorithm reduces interference between the MW modules. This increases flexibility in selecting the installation site.
Flexible installations can be carried out quickly and error-free due to features like Auto Walktest and the new End-of-Line concept (EoL).
Key Features include:
  • Unmatched detection performance based on patented MAGIC mirror technology
  • High immunity against false alarms
  • 12m volumetric optics with undercrawl protection – 20m gapless curtain (option)
  • Unique End-of-line concept eliminates time-consuming resistor wiring
  • Flexible, fast and error-free installation with sensitivity adjustment and pet immunity (option)
  • Compliance with latest approval standards such as VdS, VSÖ, INCERT, NF, IMQ, SBSC, etc.
  • Modern and elegant design
  • Low power consumption
Reliable detection
Thanks to the patented MAGIC mirror technology, intruders are detected effectively and reliably. The new double-mirror principle provides homogeneous coverage and sensitivity to all areas within the detection field. The proven and enhanced Matchtec algorithm supports the innovative mirror optic.
High hurdles for intruders
A detector cannot be identified by its housing. Potential intruders – when confronted with MAGIC motion detectors – must assume the highest security level (e.g. EN 50131-2-4 Grade 3) irrespective of the actual detector type.
Low current consumption
State of the art energy concepts and electronic components provide low current consumption. Not only energy costs are decreased across the years of utilisation but also more cost efficient uninterrupted power supply units (like batteries) can be used in the intrusion panels.
High security level
The integrated anti-mask function reliably detects any potential covering of the detector. In addition to this, the sophisticated mirror design ensures full under-crawl protection. Therefore, MAGIC DUAL detector PDM-IXx12T complies with the highest security standards, such as VdS Class C, EN 50131-2-4 Grade 3 and many more.
Error-free installation
Due to pre-fitted End-of-Line (EoL) resistors, the detectors are ready for use with Vanderbilt`s alarm panels (SPC and Sintony). Thus, the time consuming and error-prone resistor configuration can be omitted. PDM IXx12/T can also be adapted to other intrusion panels by simply replacing the pre-fitted resistors with numerous optionally available plug in EoL boards.
Fast & easy set-up
The new Auto Walktest feature accelerates the installation of the detector. Verifying the installation and operation of the detector by means of a Walktest no longer requires repeated openings of the detector nor adapting DIP switch settings.
Pet immunity: yes (option)
Set/unset input: LOW ≤ 1,5 V / HIGH ≥ 3,5 V RPull-up (internal) = 470 kΩ
Walking speed: 0,2 ... 3,0 m/s / 0,2 ... 3,0 m/s
EOL resistor: RI = 4.7 kΩ ±5%, 250 mW RF = 2.2 kΩ ±5%, 250 mW REoL = 4.7 kΩ ±5%, 250 mW
Detection characteristics / range: Volumetric / 12 m
Microwave (MW): 10.587 GHz
Approval: NF&A2P Grade 2 + RTC (pending) EN50131-2-4 grade 2
Current consumption: 4.8 mA (rms) 9.0 mA (max peak)
Colour: RAL9003
Sensitivity evaluation mode: 6 settings
Weight: 0.138 kg
Dimensions (W x H x D): 57 x 128 x 32 (mm)
Operating temperature: - 10° ~ + 55°C
Storage temperature: - 20° ~ + 60°C
Walk test input: LOW ≤ 1,5 V / HIGH ≥ 3,5 V RPull-up (internal) = 470 kΩ
Air humidity (EN 60721): < 95% RH, non-condensing
Housing protection (EN 60529): IP41 / IK02
Optical system: MAGIC mirror
Supply voltage: 9 ~ 16 VDC (12 V nom.)
  • Model: PDM-IXE12
  • Manufactured by: Siemens/Vanderbilt
Qty Discounts Off Price
1-9
£33.93
10+
£32.23
£33.93 Ex VAT
